Tässä tämä lista automaattilaatikon vikakoodeista joka minulla on:
17 Solenoid 1-2/3-4 (voltage low)
21 Throttle position sensor (v low)
22 Throttle position sensor (v high)
23 Coolant temperature switch (v high)
25 Solenoid 1-2/3-4 (v high)
26 Solenoid 2-3 (v low)
27 Connection solenoid 2-3/Solenoid TCC
28 Solenoid 2-3 (v high)
29 TCC solenoid (v low)
31 No engine RPM signal
32 Pressure regulator solenoid (v low)
33 Pressure regulator solenoid (v high)
36 TCC solenoid (v high)
38 No transmission input RPM signal
39 No transmission output RPM signal
41 Gear error hydraulic fault (usually internal transmission mechanical failure)
42 Pressure regulator solenoid (short circuit)
47 Down shift protection
48 Battery (v low)
49 Battery (v high)
56 Selector switch (incorrect signal)
65 AT oil temperature sensor (v high)
66 AT oil temperature sensor (v low/high)
67 AT oil temperature sensor (v low)
75 Transmission switch (v low)
76 Engine TPS load (signal incorrect)
77 Kickdown switch (v low)
78 AT shift time (too long)
