EGR mäkeen, auto kuntoon!
Iro
Re: EGR mäkeen, auto kuntoon!
Viesti Kirjoittaja Iro »
"the egr cheater talks directly to the ecu and has nothing to do with the coilpack"
Faktaa.
ovc2z22yh
Viesti Kirjoittaja ovc2z22yh »
stewedw: Just an update -- it was the coil pack back then that failed. Very odd now that 6 months later the same thing is happening? Any ideas if the egr cheater can cause this as the spark plugs and oil were changed in feb, the plugs were black!!! I changed the coil pack and bliss ever since up until last wednesday. The car is now very hisitant 1k rpm - 2k rpm regadless of gear, throttle postition etc. I checked the oil which is fine, the air intake was fine and I cleaned out the throttle body, removed the battery for a few mins (as eml on) and then re-fitted the cheater from sratch making sure all the connections were fine etc.
Tuossa on resetoitu (removed the battery) myös long_term_fueltrimmit ja kaveri on luullut osan vaihdon auttaneen.
K.o ketjussa sattuu myös yllättävän paljon (muka?) diodivikoja simulaattoriin, kun vikavalo syttyy ja siitä syytetään diodeja.
