Säädä kaasutin - Carburetor adjustment
This forum is for English language discussion about Opels, Opel Club Finland and related issues
D13N
Viesti Kirjoittaja D13N »
I own a 81' -(z)- Opel Kadett with a 1.3N engine.
In the beginning of this year was the carburetor (Solex 35PDSI 9276953) renewed and I have since then the problem to adjust the carburetor so that the car runns smoothly by itself with idle.
I want to learn how to properly do that (what I have been doing wrong) and am looking for someone who can help me adjuting the carburetor and choke so that the car's idle is again smooth and constant.
I live in the South of Espoo, feel free to contact me, payment of course possible
//Stephan
Re: Säädä kaasutin - Carburetor adjustment
Viesti Kirjoittaja Juho M-P »
Start by turning idle mixture screw to bottom. Then open it 1,5 turns. Start engine and try to find "sweet spot" by adjusting mix screw.
D13N
Hei Juho,
thank you for your reply. I have been trying that and with that setting I have the issue that the car wont run without choke, even though the engine is warm and with carefully adjustment of the screw. What could be the reason? :/
Idle jet is too small. For modern fuel you need bigger
D13N
Thank you!
May I ask where it is located?
That one with one wire, it is electrically actuated to prevent backwards running after shutdown.
