Vectra B ECU-ECM?
TeBa
Vectra B ECU-ECM?
Viesti Kirjoittaja TeBa »
Onko X18XE1 vm.2000 Vectrassa erikseen ECU:a, vai onko se vaan tuo ECM paketti tuolla konetilassa?
Eli se on moottorin ohjausyksikkö?
EDIT:
Eiköhän se ole sitten :)
Wikipedia kirjoitti:In automotive electronics, an electronic control unit (ECU), also called a control unit or control module, is an embedded system that controls one or more of the electrical subsystems in a vehicle. Some modern cars have up to 70 ECUs, including:
* Engine Control Unit
o also called Powertrain Control Module (PCM)
* Transmission Control Unit - TCU
* Telephone Control Unit - TCU
* Man Machine Interface - MMI
* Door Control unit
* Seat Control Unit
* Climate Control Unit
Managing the increasing complexity of ECUs and number of ECUs in a vehicle has become a key challenge for OEMs.
MB W201 190D OM605 powered with Holset
Juuha
Viesti Kirjoittaja Juuha »
Sama kysymys... Miten Corsa 1.0 vm. -98? Mihin tieto tallentuu? Esim. vikakoodit?
