Diesel ja lisäaineet
jjvirtan
Re: Diesel ja lisäaineet
Viesti Kirjoittaja jjvirtan »
Kyllä itse kannatan nykyään 2t öljyn lisäämistä polttoaineeseen,niilläkin jotka ajaa VP44 ruiskutuspumpulla,on tullut ilmi niin monta ennakonsäätömäntää jotka ovat mennet jumiin tai pilalle.
C1. Vectra 1.8 GTS
Astra G 1.6 8V
kapiteeli
Miten olisi 2-t öljyn tilalla Red Line RL-2 diesel-lisäaine, pullon pitäisi riittää 1000 l löpöä (tai tuo aiemmin mainittu Red Line 85 PLUS diesel-lisäaine)
http://www.roadmachine.fi/rl2tt.html
Löysin netistä mielenkiitoisen artikkelin "a research study on diesel fuel Lubricity Additives"
In this study we will test multiple diesel fuel additives designed to replace lost lubricity. The primary component of this study is a side-by-side laboratory analysis of each additive’s ability to replace this vital lubricity.
How Diesel Fuel Is Evaluated For Lubricating Ability:
Diesel fuel and other fluids are tested for lubricating ability using a device called a “High Frequency Reciprocating Rig” or HFRR. The HFRR is currently the Internationally accepted, standardized method to evaluate fluids for lubricating ability. It uses a ball bearing that reciprocates or moves back and forth on a metal surface at a very high frequency for a duration of 90 minutes. The machine does this while the ball bearing and metal surface are immersed in the test fluid (in this case, treated diesel fuel). At the end of the test the ball bearing is examined under a microscope and the “wear scar” on the ball bearing is measured in microns. The larger the wear scar, the poorer the lubricating ability of the fluid. Southwest Research runs every sample twice and averages the size of the wear scar.
The U.S. standard for diesel fuel says a commercially available diesel fuel should produce a wear scar of no greater than 520 microns. The Engine Manufacturers Association had requested a standard of a wear scar no greater than 460 microns, typical of the pre-ULSD fuels. Most experts agree that a 520 micron standard is adequate, but also that the lower the wear scar the better.
THE RESULTS:
These results are listed in the order of performance in the HFRR test. The baseline fuel used in every test started at an HFRR score of 636. The score shown is the tested HFRR score of the baseline fuel/additive blend.
Also included is the wear scar improvement provided by the additive as well as other claimed benefits of the additive. Each additive is also categorized as a Multi-purpose additive, Multi-purpose + anti-gel, Lubricity only, non-conventional, or as an additive capable of treating both gasoline and diesel fuel.
As a convenience to the reader there is also information on price per treated tank of diesel fuel (using a 26 gallon tank), and dosage per 26 gallon tank provided as “ounces of additive per 26 gallon tank”.
In Order Of Performance:
---- IMPROVED LUBRICATING QUALITIES OF DIESEL ----
1) 2% REG SoyPower biodiesel
HFRR 221, 415 micron improvement.
50:1 ratio of baseline fuel to 100% biodiesel
66.56 oz. of 100% biodiesel per 26 gallons of diesel fuel
Price: market value
2)Opti-Lube XPD
cetane improver, demulsifier
HFRR 317, 319 micron improvement.
256:1 ratio
13 oz/tank
$4.35/tank
3)FPPF RV, Bus, SUV Diesel/Gas fuel treatment
Gas and Diesel
cetane improver, emulsifier
HFRR 439, 197 micron improvement
640:1 ratio
5.2 oz/tank
$2.60/tank
4)Opti-Lube Summer Blend
Multi-purpose
demulsifier
HFRR 447, 189 micron improvement
3000:1 ratio
1.11 oz/tank
$0.68/tank
5)Opti-Lube Winter Blend
Muti-purpose + anti-gel
cetane improver
HFRR 461, 175 micron improvement
512:1 ratio
6.5 oz/tank
$3.65/tank
6)Schaeffer Diesel Treat 2000
cetane improver, emulsifier, bio-diesel compatible
HFRR 470, 166 micron improvement
1000:1 ratio
3.32 oz/tank
$1.87/tank
7)Super Tech Outboard 2-cycle TC-W3 engine oil
Unconventional (Not ULSD compliant, may damage 2007 or newer systems)
HFRR 474, 162 micron improvement
200:1 ratio
16.64 oz/tank
$1.09/tank
8)Stanadyne Lubricity Formula
Lubricity Only
demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 479, 157 micron improvement
1000:1 ratio
3.32 oz/tank
$1.00/tank
9)Amsoil Diesel Concentrate
Multi-purpose
demulsifier, bio-diesel compatible, alcohol free
HFRR 488, 148 micron improvement
640:1 ratio
5.2 oz/tank
$2.16/tank
10)Power Service Diesel Kleen + Cetane Boost
Multi-purpose
Cetane improver, bio-diesel compatible, alcohol free
HFRR 575, 61 micron improvement
400:1 ratio
8.32 oz/tank
$1.58/tank
11)Howe’s Meaner Power Kleaner
Multi-purpose
Alcohol free
HFRR 586, 50 micron improvement
1000:1 ratio
3.32 oz/tank
$1.36/tank
12)Stanadyne Performance Formula
cetane improver, demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 603, 33 micron improvement
480:1 ratio
6.9 oz/tank
$4.35/tank
---- HAD NEGLIGIBLE EFFECT ON LUBRICATING QUALITIES OF DIESEL ----
13)Used Motor Oil, Shell Rotella T 15w40, 5,000 miles used.
Unconventional (Not ULSD compliant, may damage systems)
HFRR 634, 2 micron improvement
200:1 ratio
16.64 oz/tank
price: market value
14)Lucas Upper Cylinder Lubricant
Gas or diesel
HFRR 641, 5 microns worse than baseline (statistically insignificant change)
427:1 ratio
7.8 oz/tank
$2.65/tank
15)B1000 Diesel Fuel Conditioner by Milligan Biotech
Multi-purpose, canola oil based additive
HFRR 644, 8 microns worse than baseline (statistically insignificant change)
1000:1 ratio
3.32 oz/tank
$2.67/tank
---- WORSENED LUBRICATING QUALITIES OF DIESEL ----
16)FPPF Lubricity Plus Fuel Power
Emulsifier, alcohol free
HFRR 675, 39 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$1.12/tank
17)Marvel Mystery Oil
Gas, oil and Diesel fuel additive (NOT ULSD compliant, may damage 2007 and newer systems)
HFRR 678, 42 microns worse than baseline fuel.
320:1 ratio
10.4 oz/tank
$3.22/tank
18)ValvTect Diesel Guard Heavy Duty/Marine Diesel Fuel Additive
Multi-purpose
Cetane improver, emulsifier, alcohol free
HFRR 696, 60 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$2.38/tank
19)Primrose Power Blend 2003
Multi-purpose
Cetane boost, bio-diesel compatible, emulsifier
HFRR 711, 75 microns worse than baseline
1066:1 ratio
3.12 oz/tank
$1.39/tank
CONCLUSIONS:
Products 1 through 4 were able to improve the unadditized fuel to an HFRR score of 460 or better. This meets the most strict requirements requested by the Engine Manufacturers Association.
Products 1 through 9 were able to improve the unadditized fuel to an HFRR score of 520 or better, meeting the U.S. diesel fuel requirements for maximum wear scar in a commercially available diesel fuel.
Products 16 through 19 were found to cause the fuel/additive blend to perform worse than the baseline fuel. The cause for this is speculative. This is not unprecedented in HFRR testing and can be caused by alcohol or other components in the additives. Further investigation into the possibilities behind these poor results will investigated.
Any additive testing within +/- 20 microns of the baseline fuel could be considered to have no significant change. The repeatability of this test allows for a +/- 20 micron variability to be considered insignificant.
Lähde: DIESEL FUEL LUBRICITY ADDITIVES STUDY RESULTS
Aabelix
Viesti Kirjoittaja Aabelix »
RL-2 käyttänyt reilut pari vuotta niinkauan kun on tuo diesel ollut ja sitä ei tarvitse kuin pikku lorauksen joka toiseen tankilliseen omilla kilometreillä puteli riittää melkein vuodeksi, mitään haittaakaan ei ole ollut ja ensikerran kun tankkiin sitä laittoi huomasi käyntiäänen silloin pehmentyvän heti, toki myöhemmin imunokan sädöllä oli vielä suurempi vaikutus pemeämpään käyntiin (1.9DTH 16venttiilinen kone)
GM TECH2 + GlobalTIS ohjelmoinnit ja ohjelmapäivitykset. Vectra C 1.9 DTH virikarttoja (EDC16C39) ECU.lle.
OpelAndy
Viesti Kirjoittaja OpelAndy »
Ite olen väliajoin lurutellut tankkiin Kemetyl Diesel -nimistä lisäainetta. On vaikuttanut ihan kelvolliselta ja
ei hirveitä maksa. Paikallinen lähialueen Shell ainakin myy tuota. Kone tuntuu reagoivan ärhäkkämmin
tai sitten kuski vain kiihtyy herkemmin... Olen laittanut n. 2000-3000 km välein eli suunnilleen joka 3:s tankki.
Linkki valmistajan tietoihin :
http://kemetyl.netblast.no/products/pro ... ct_id=4423
(En saanut pdf-tiedostoa auki...)
Opel Zafira B 1,9 CDTI AT -07 163 tkm Z19DT 8-venttiilinen, hyvin nakuttaa ja rullaa...
EX 5 Pösöä: 309 1.3 GR, 2x306 (1.9 SRDT ja 1.6 XR), 307 wagon 1.6 bensa ja 407 1.6 HDI SW
giggs11
Viesti Kirjoittaja giggs11 »
kuinka paljon 2t-öljyä kanattaa laittaa diselin sekaan . jokin suhde olisi kiva niin voisin kokeilla :peukku: toimiiko mulla että naputus pienenee. :lollis:
rgs1
Viesti Kirjoittaja rgs1 »
Yks sakemanni oli kirjoittanut, jotta 0.25%, mutta tuohan on jo aika paljon, kun tuosta tulee desilitra/40 litraa. Puoli desiä tankilliseen on kohtalainen suuruusluokka. Ei anna aihetta mitta-astian käyttöön :D
jjvirtan
Näkyy synteettinen 2t öljy maksavan n. 5e litra ja tavallinen jopa vain 2.9e!pakkasilla synteettisen käyttöä voi miettiä,se sekoittunee silloin paremmin.
C1. Vectra 1.8 GTS
Astra G 1.6 8V
