Insignia tee se itse
ddude
Re: Insignia tee se itse
Viesti Kirjoittaja ddude »
Joo tuossa dnl filessä on siis se versiopäivitys ja toi "blue carbon" teema samassa.
Jossain oli pelkästään muunnos CD 500->DVD 800, ilman mitään teemaa jos hakee mahd. OEM lookia.
En vain löydä sitä just nyt.
Tässä koko ohje englanniksi copy pastettuna tuolta ie foorumilta:
Convert CD500 to DVD800 - Step by Step Guide.
Windows Requirements
Windows 7+ (with built in CD Burning features)
WinRAR (Shareware software for extracting .rar files, this software is similar -but better- than WinZip/Zip)
A little bit of IT expertise (depending on what you're wanting to achieve!)
Time & Patience
Mac Requirements
A CD Writing application (I use Toast, but this is not free)
Time & Patience
Method
You need to download a modified version of the GM Update Disc as linked below. Once downloaded you need to burn the contents to a CD (or copy the files to a USB drive if you're MY2011). Depending on the file you choose, will depend on the outcome. Some themes include the CD500 to DVD800 patch and as a result add 3D navigation views, some do not include the patch (Infinity MY2009/MY2010 does not for example). Whichever update you choose may or may not erase your current maps. In many cases, the maps tend to remain in the memory of the CD500 (MY2009/MY2010) despite the warning suggesting otherwise (this cannot be guaranteed). Retaining the maps on MY2011+ is a bit more miss than hit, with more users reporting the need to reload the maps.
Note:
For MY2011 users upgrading to the DVD800 firmware, CD500 map update discs are no longer recognised and you need to use DVD800 maps - pay attention to this, as maps are almost always deleted when performing this change on MY2011 cars. For MY2009-10 vehicles, you can still use the CD500 maps after the upgrade.
Note: Everything you do - you do at your own risk . If in doubt do not attempt this. It is almost guaranteed that carrying out this procedure will void any warranty on the affected items. Due to the nature of the Vauxhall radio setup, a fix could cost in excess of £500.00.
Upgrading CD500 to DVD800
- introduces 3D Maps and Tours functionality to CD500 users.
If you want to keep the original themes, but just patch up to a DVD800, and get the 3D Navi view, and Tours function, then this is all you need. Download the file and then skip to the 'Performing the Upgrade' section towards the bottom.
Download
Posted Image
MY2009/MY2010 (CD500 to DVD800 patch only)
MY2011 (CD500 to DVD800 patch & Blue Carbon theme)
(you could replace all instances of images.uli with the one from your theme, giving theme & DVD800 patch)
If you want to change the appearance, then download a theme from below and read on.
Applying a Theme to your CD500/DVD800
- see images below, some of these themes may also add the 3D Maps and Tours functionality.
Downloads
Posted Image
"Carbon" Theme - MY2009/MY2010
"Carbon" Theme - MY2011
Posted Image
"Adam" Theme - MY2009/MY2010
"Adam" Theme - MY2011
Posted Image
"Apofigey v2" Theme - MY2009/MY2010
"Apofigey v2" Theme - MY2011
Posted Image
Posted Image
Engine1992's "Red" Theme - MY2009/MY2010
Engine1992's "Red" Theme - MY2011
Posted Image
Engine1992's "Infinity" Theme - MY2009/MY2010
Engine1992's "Infinity" Theme - MY2011
Engine1992's "Infinity" Theme, Remixed by Vini - MY2009/MY2010
- debranded (created my own standby screen, removed all Infinity references and made a few other tiny alterations that no one would notice)
Download one of the above files, they range from 150MB to 300MB. After the download has finished, you should have a .rar file (similar to a .zip), this needs to be extracted using one of many free tools available online. My recommendation would be WinRAR on Windows, or Keka on Mac.
Once extracted, you have two options; burn the 'theme' as is, or attempt to modify the theme yourself. Modifying the theme requires time, patience and knowledge. I'll briefly touch upon modifying later, for now, I'll explain how you simply prepare a theme for install.
After extracting the download, you will either have a folder called /dnl/, or a folder of the filename, and inside that /dnl/.
If you're only interested in using one of the pre-made themes, then you simply need to burn this /dnl/ folder (and its contents) to a CD. It is recommended that you burn the disc at a slower than normal speed, 4x for example. In days of yore, older drives, with crappy lasers used to be very fussy at reading discs, and one trick to combat this, was to burn at a slow speed. MY2011+ users also have the option of using a USB drive, this must be formatted as FAT32.
Burning to CD-R in Windows;
-In Windows, right click on /dnl/
-Goto "Send to"
-Select your DVD/CD writer
-Wait 30 seconds whilst the files copy over to cache
-Click on your actual DVD/CD writer in Windows Explorer
-Choose burn files to disc
-Choose the bottom option (master I think it is) and give the disc a title (I went for DNL)
-Burn using slowest speed
-Wait 5 minutes for the disc to burn
Then... with your freshly prepared update disc/USB drive at the ready, head out to the car and switch on the ignition (I had the engine running). Turn the radio on, so that you can see whats on screen and hear the music. Ensure you're on a station you enjoy, and that the volume is at a nice level as you cannot change this during the update. When you're happy insert the USB drive, or CD and follow the onscreen prompts. Once you confirm the update two or three times, it will begin at which point you're pretty much stuck with whatever volume/station you have on, so make sure you are happy as the process takes roughly 20-30 minutes.
During the update, there are certain percentages where the update appears to have stalled. Fear not, be patient. As you're erasing and writing the flash, any interruption could be fatal to the stereo. So just leave it well alone.
After the update, the radio will automatically turn off, and back on, then after a minute or two, it will go off again, and turn back on to the 'standby screen'. At this point you can turn it on again. After a few more minutes, the time and date should set. After this, you're free to explore. Please note, favourites and stored stations will be lost.
Note Some MY2011-> users appear to have experienced issues if the car is fitted with the original Bluetooth module, and losing the ability to use your steering wheel control. I am unable to decipher the foreign language on this one, and as I am MY2009, I did not experience this issue. What I would say, is that if you're MY2011+ and have Bluetooth, do your own digging...
Editing/Creating Themes
If you're wanting to customise a theme, or make your own. You'll need the uli GM Files Extractor Ver 2.8.5, time, patience and photo editing skills... I suggest reading the threads over at insignia-club.pl (links at the bottom of this), which should provide enough information for those wanting to go that extra step.
Downgrading DVD800 to CD500/Returning to Factory Settings
MY2010 users can downgrade back to the original CD500 state by simply running the Original Update Disc.
MY2011 users who patched their CD500 to DVD800 can downgrade back to CD500, by burning this Downgrade Disc, and running it in the radio.
MY2011 users who want to restore to factory settings can then run the Original MY2011 Update Disc.
Posted Image
MY2009/MY2010 - CD 'SOFTWARE UPDATE', V-2010/1.0 (13343362)
Posted Image
MY2011 - CD 'SOFTWARE UPDATE', V-2011/1.0 (22795977)
Please note, the above links only work if your Radio thinks its a CD500 (no 3D maps, no Tours etc), you may need to downgrade first, using this.
Again, everything you do - you do at your own risk . If in doubt do not attempt this. It is almost guaranteed that carrying out this procedure will void any warranty on the affected items. Due to the nature of the Vauxhall radio setup, a fix could cost in excess of £500.00.
Credits & Sources
insignia-club.pl, yerry, Engine1992, ak_zyzop
http://www.insignia-...?showtopic=8094
http://insignia-club...lacz-t1089.html
http://insignia-club...enia-t733.html
http://insignia-club...y2011-t281.html
Guide credits Vini
Tuolla polski foorumilla voi olla jo lisääkin noita, ei ole enää tunnuksia sinne.
Lisäksi vm2011-> on karttojen hukkumisen lisäksi riski että blutooth ei enää toimi.
Ilmoittele t3mu jos ja kun levy saapuu.
Saan itse orkkiksen lähes samaan hintaan mutta ihan mielenkiinnosta kiva tietää jos joku pystyy jo noita kopioimaan.
EDIT: foorumisofta ei osaa hakea noita linkkejä copy pastella joten tässä linkki ko threadiin jos joku tarvitsee ladata jotain sieltä:
http://www.insignia-enthusiast.org/foru ... 019&st=120
teemuk
Viesti Kirjoittaja teemuk »
Löysin itsekin tuon yllä mainitun sivuston. Sieltä löysin toimivan päivityksen. Ja karttatkin näky pysyneen tallessa :D tuota bt:tä en kerenny koittaa kun jo piti työmaalle kiirehtiä. Kettu kuittaa avusta!
-Insignia 4x4 OPC -14
-Astra h gtc 2.0t -06
-Astra J -11 1,4t -10
-Omega 2,5 v6 -94
-kadett sedan bee x4
t3mu
Viesti Kirjoittaja t3mu »
Hmmm, mielenkiintoista että aikaisemmin kun levyä kyseli niin mistään ei löytynyt. Nyt niitä onkin sitten ilmeisesti joka nurkalla :bonk: Tosiaan aino mikä löytyi, kun sen ostamista suunniteltiin oli n. 170e maksava levy. Tottakai sen olisi varmasti suomesta ostanutkin, mutta hinta oli tosiaan ihan eri mitä lupasivat saksasta.
jala
Viesti Kirjoittaja jala »
Masi kirjoitti:
jala kirjoitti:Paikallisesta merkkiliikkeestä löytyi 13393912 hyllystä, hinta nykyään 25€, ihan hyvä korotus. Kyselin vaihtokampanjasta, ei ole kuulemma ollut mitään kampanjaa, tämä vastaus tuli kyllä mitään mistään varmistelematta hihasta, mutta ihan sama koska joka tapauksessa uuden joutuu ostamaan.
Vai ei ole ollut kampanjaa - valitettavasti vastaus ei minua yllätä.
Tuossa nyt kuitenkin koodi tähän jo päättyneeseen kampanjaan: 11-P-021
Vilautin tuota koodia tiskillä, ei kuulemma näe tuolla numerolla mitään. Ukkelit vähän perään katselivat kun lähdin pois tyyliin "...pitääkö tänne tulla pätemään...", taisivat laittaa vähintään rekkarin "asiakas on mulq" listalle. Mutta tämä tapahtuma oli n. viikko sitten, yllättäen kytkin on sen jälkeen ruvennut pelamaan. Syynä lienee auton tallissa pitäminen muutaman päivän, juuri ennen pakkasia oli täällä helvetin märät kelit ja kosteutta oli reilusti joka paikassa. Joka tapauksessa vaihdan kun jaksa kytkimen (tai sitten kun on pakko), hyvä kun on valmiina jemmassa.
Insignia CDTi 118 Sports Tourer 2010 AT
Masi
Viesti Kirjoittaja Masi »
jala kirjoitti:
Masi kirjoitti:
Mistähän lienee "ukkelisi" etsineet tuolla koodilla... EPC:täkö :lollis: ... :no: :no: :no: ... aivan perusasioita tuommoiset...
teemuk
teemuk kirjoitti:Löysin itsekin tuon yllä mainitun sivuston. Sieltä löysin toimivan päivityksen. Ja karttatkin näky pysyneen tallessa :D tuota bt:tä en kerenny koittaa kun jo piti työmaalle kiirehtiä. Kettu kuittaa avusta!
Hmm...
Tuolta linkin kautta ladattu tiedosto (alla linkki) ei tainnu päivittää kuin tuon teeman :roll: Siis tuossa alla oleva :-? Siksi varmaan jäi ne alkuper.kartatkin talteen. No en mä kyllä jääny katteleen mitä siellä näytössä lukee kun jätin lataamaan. Kyllä siinä näytössä oli alussa varoitus karttojen poistosta muttei ne mihinkään hukkunu samoin bt toimii. :lollis:
https://mega.nz/#!AdAH0IrK!0KwS-4mL2jZA ... pcBHPHIVvA
-Omega 2,5 v6 -94
t3mu
t3mu kirjoitti:
ddude kirjoitti: Karttalevyä ei pysty kopioimaan, siinä on Korealaisen Settec yhtiön Alpha Rom suojaus jota ei ainakaan mun tietojen mukaan ole pystytty murtamaan.
Jahas, ainakin saksassa väittivät että heiltä löytyy laitteet suojauksen murtamiseen. Minä en sitä ole hoitanut, mutta foorumilta nimimerkki -Jan- on ollut yhteydessä saksalaisen foorumin kautta. Siellä niitä on kuulemma kopioitu enemmänkin ja ihan onnistuneesti.
Noniin nyt pitkän odotuksen jälkeen vihdoin dvd suomessa, vielä tosin toisella käyttäjällä mutta huomenna saan sen käsiini. Tässä siis toimiva kopio dvd koko euroopan uusimmista kartoista ja hinta oli 74e lähetettynä. Todistetusti siis jo ladattu ja kokeiltu ja todettu toimivaksi cd500->dvd800 muutetussa soittimessa.
anzie
Viesti Kirjoittaja anzie »
Löytyykö jostain facelift-Insignian sisätilapolttimoiden kantoja? Haluaisin ledit laittaa tilalle.
Ja peruutusvalo myös.
tempera
Viesti Kirjoittaja tempera »
Mulla on sama vika. Mutta avaimesta painamalle luukku aukeaa. Tulen sillä toimeen ja jos sattuu että avain jää paksiin ja isken luukun kiinni niin takapenkin kääntämälä pääsee paksiin. Jos taas koko auto menee lukkoon niin kotoa on haettava varaavain, Mersussa oli mulla tiirikka lompakossa varalla millä pääsi autoon kuskin ovesta.
ISIGNIA CDTI :banghead: 2009 KOTKA :lollis:
ddude
t3mu kirjoitti:
t3mu kirjoitti:
Toimiko tämä levy kuten pitikin?
Jos kyllä niin pistätkö linkkiä, YV:llä jos et halua tässä jakaa.
t3mu
Toimii, niinkuin ylhäällä lukeekin. En tiedä mistä tilattu, koska -Jan- hoiti koko homman.
ddude
t3mu kirjoitti:Toimii, niinkuin ylhäällä lukeekin. En tiedä mistä tilattu, koska -Jan- hoiti koko homman.
Ok.
Saisitko kysyttyä tuota jotenkin siltä, ei itse näytä olevan hirveän aktiivinen foorumilla yhdellä viestillään...?
t3mu
ddude kirjoitti:
Ok.
Ei ole enää yhteystietoja, täältä sain kiinni viimeksi.
tempera
Mulla on se präluukun kytkin myös rikki mutta ei niinkauan hätää kun luukun saa avaimella auki. Toinen on perävalojen vedenpitävyys. Nyt kun on syksy ja olen pesettänyt auton niin perän pakitusvalojen sisällä on vettä. Otin valot irti ja vein sisään. Sitten otin polttimoosan pois kummastakin ja lämpöpuhaltimella kuivasin veden pois. Näytti tulevan nurkista vettä lasin välistä. Pistin silikonia ympäri koko kotelon ja nyt vaan odotetaan jos vettä ei tule. Sitten on viimeinen testi kun käytän auton pesussa. :hypocrite: -(z)-
Viesti Kirjoittaja Robertx »
Kannattaa laittaa paksua kumi tiivistettä niiden takavalojen ympäri, jotta on tiivis niiden luukun muovien pintaan. Samoin kannattaa tiivistää takalasin alareunan ja sen koristelistan väli. Niistä menee vettä jopa ajon aikana takaluukun sisälle. Takavalot kypsyy ja samoin se luukun avausnappi.
