Kadett B + Manta B taka-akseli
Astrona
Viesti Kirjoittaja Astrona »
My finnish is even worser than english :smile:
After putting 18E engine to my Kadett B 1.1, i've destroyed already 2 rear-axles.
I've seen Manta B 2.0S rear-axle (from a picture)- it is very similar to Kadett B's axle. The location of fittings etc.
Has anyone done it? Manta/Ascona B axle to Kadett B/C.
Can i use Kadett's torque tube into Manta B's differential? I haven't seen that part on Manta. Omega has a flange.
At the moment i Kadett B stock torque-tube/cardan/driveaxle (or whatever it is). BUT Rekord 18S gearbox and the first 25cm of that tube (and the rubber part).
Please help, on my other car toothed belt was broken, on the same day as kadett's axle "snail".
Astrona
I think i got the problem solved in MIGweb.
http://www.migweb.co.uk/forums/showthre ... ost1646756
