Ilmoittivatko siellä huollossa vikakoodit ?? Erikoiselta kuulostaa, että ECU rikkoisi kaasuläpän.
Tuollaisen löysin Opelin huoltoinformaatiosta :
Field Remedy: 2033
Subject: Engine X18XE1 - Engine stalls, trouble code P0100 and/or P0110 set
Models: Engines: Option:
Astra-G 1998...2001,Vectra-B 1998...2001,Zafira 1999...2001 X18XE1,X18XE1,X18XE1
Complaint: Engine stalls - trouble code P 0100 and/or P0110 is set.
Cause: Internal ECU ground connection interupted.
Production:
Remedy:
In case of customer complaint install two additional ground cable to
the engine control unit. Use special parts as shown below.
Procedure:
1. Disconnect battery.
2. Remove upper engine cover.
- Remove 2x screw
3. Unlatch and detach cable connector from engine control
unit (3) (Picture I).
4. Open cable duct (1).
- detach 2x hose clamp (arrows)
- detach 2x hose (2)
- clip off cable duct
5. Identify cable ground air mass meter (yellow cable) and ground cable
coolant temperature sensor (brown cable)(Picture II).
Notice:
Follow both cables from current module to the middle of the cable duct
and proceed with following steps.
- check ground cable air mass meter for continuity
against Pin 48
- check ground cable cooling sensor for continuity
against Pin 07
6. Connect ground cable air mass meter with special part
(yellow cable) (Picture III).
- cut and dismantle cable (1) in the centre area
- mount shrink hose
- crimp end of ground cable air mass meter and special part (2)
7. Connect ground cable coolant temperature sensor with special part
(brown cable).
- cut and dismantle cable (1) displaced from crimping
position of ground cable air mass meter
- mount shrink hose
- crimp end of ground cable cooling sensor and special part (2)
Notice:
Produce Y-connections displaced from each other by crimping.
The original connection remains unchanged. The end of special
part must point in direction of control unit.
8. Heat up 2x shrink hose (1) (Picture IV).
9. Install both special parts (1) to the engine control unit (2)
(Picture V).
- remove 2x screw
- attach each screw with one special part
10. Install protection hose (1) between wiring harness and engine
control unit (Picture VI).
- Install protection hose to both special parts and insert it
in wiring harness
11. Close cable duct
- clip on cable duct cover
- attach 2x hose
- attach 2x hose clamp
12. Connect battery.
13. Delete trouble codes.
14. Program volatile memories.
Spare-Parts: Part-No.: Catalogue-No.:
Protection hose 5m 90443557 12 88 103
Special part ground cable 9201820 90 12 031
Shrink (package 50 pieces) 90543875 12 86 666
Crimp (package 100 pieces) 90543866 12 86 664
FunctionalGroup: J - Engine
Complaint Group: 18 - Poor Drivebility
Trouble Code: P0100 / P0110
ECUn sisäinen maadoitus siis katkennut... lisättävä 2 maajohdinta.
Valitettavasti kuvat eivät kopioituneet mukaan.
ja aina vain paranee tyhjäkäynti ei pelitä enää :D
Re: ja aina vain paranee tyhjäkäynti ei pelitä enää :D
Altti450
Vähän luulen, että tuo kone on x18xe1.
Mulla on tuolla muutama kuva omasta rempasta. Ei tartte ottaa irti, kuten minä tein vaan sinne voi suihkia tuota puhdistusainetta ja pyyhkiä rätillä enimmät moskat pois. Läppää kannattaa avata sormilla ja ruiskutella sinnekin ja pyyhkäistä puhtaaksi. Tuo kuvien kone on x18xe1.
Tosiaan minä olen tehnyt omaan koneeseeni tuon lisämaadoituksen. Muistaakseni lisättiin ilmamassamittarin sekä termostaatin? maajohtoihin johtosarjaan. Kolvasin piuhat johtosarjaan ja toiset päät liittimellä ecuun kiinni.
Samaa mieltä olen , että kone on X18XE1 . koska Opelin huoltoinformaatiossa ei ollut tuohon vuosimalliin tarjolla X18XEL - konetta.
