Laitoin vertailun helpottamiseksi omasta z18xe stä tietoja vastaavasta käyntitilanteesta, eli käy tyhjäkäyntiä.
On helpompi verrata keskenään kun costellon zafiran tiedot on rinnatusten.
Sitä en sano että autoni moottori olisi tiptop tai erikoisen hyvässä kunnossa muttei ainakaan pätki satasessa ja toimii muutenkin hyvin.
Koodi: Valitse kaikki
Oma Z18XE kosla | costelli Z18XE ?
Battery Voltage 14.0 V 13.9 V
Main Relay Active Active
Fuel Pump Relay Active Active
APP Sensor 1 (Accelerator Pedal Position) 0.96 V 0.96 V
APP Sensor 2 (Accelerator Pedal Position) 0.47 V 0.47 V
Calculated Pedal Position 0 % 0 %
TP Sensor 1 (Throttle Position) 0.47 V 0.49 V
TP Sensor 2 (Throttle Position) 4.59 V 4.51 V
Calculated Throttle Position 3 % 4%
Throttle Position Idle Idle
Engine Speed 778 RPM 828 RPM
Mass Air Flow Sensor 0.65 V 0.43 V
Mass Air Flow Sensor 11 kg/h 8 kg/h
Coolant Temperature 1.95 V 3.08 V
Coolant Temperature 79 °C 53 °C
Intake Air Temperature 1.06 V 1.84 V
Intake Air Temperature 46 °C 24 °C
Tank Sensor 4.27 V 7.65 V
A/C Information Switch (Air Conditioning) Inactive Inactive
A/C Pressure (Air Conditioning) 180 kPa 500 kPa
Brake Switch 1 Inactive Inactive
Brake Switch 2 Inactive Inactive
Clutch Switch Inactive Inactive
Vehicle Speed 0 km/h 0 km/h
Cruise Control Tip Switch Inactive Inactive
Cruise Control Inactive Inactive
Vehicle Speed in Cruise Control Range Inactive Inactive
Fuel Tank Ventilation Valve 9 % 2 %
Knock Control Inactive Inactive
Intake Manifold Valve 1 Inactive Inactive
B1S1 O2 Sensor Heater (Bank 1 Sensor 1) Active Active
B1S1 O2 Sensor (Bank 1 Sensor 1) 294 mV 196 mV
B1S1 Air/Fuel Ratio (Bank 1 Sensor 1) Rich Lean
B1S2 O2 Sensor Heater (Bank 1 Sensor 2) Inactive Active
B1S2 O2 Sensor (Bank 1 Sensor 2) 412 mV 274 mV
B1S2 Air/Fuel Ratio (Bank 1 Sensor 2) Lean Lean
O2 Sensor Loop Closed Closed
B1 Short Term Fuel Trim (Bank 1) 2 3
A/C Relay (Air Conditioning) Inactive Inactive
A/C Cutoff Mode (Air Conditioning) Underpressure System OK
Malfunction Indicator (MI) Off On
Service Vehicle Soon (SVS) Indicator Off Off
Desired Idle Speed 787 RPM 812 RPM
Idle Speed Offset Inactive Inactive
Vehicle Acceleration 0.0 m/s2 0.0 m/s2
Ignition Dwell Angle 2.1 ms 2.1 ms
Injector Time 3.3 ms 2.3 ms
Ignition Spark Angle 11.7 °CA 8.7 °CA
B1 Knock Sensor Signal (Bank 1) 0.2 V 0.3 V
Knock Retard Cylinder 1 0 °CA 0 °CA
Knock Retard Cylinder 2 0 °CA 0 °CA
Knock Retard Cylinder 3 0 °CA 0 °CA
Knock Retard Cylinder 4 0 °CA 0 °CA
Relative Engine Load 0 % 2%
ETC Limp Home Mode (Electronic Throttle Control) Inactive Inactive
Electronic Throttle Control Learn Counter 0 0
Fuel Tank Ventilation Valve Active Inactive
Ps. Tarkista myös alempi lamdan johdinsarja ja varsinkin liitin. Liitin pitää painaa todella luotettavasti ja lujaa kiinni.
Samoin imusarjan alla on pahassa paikassa muuttuvamittaisen imusarjan säätöliitin jota on alakauttakin vaikea edes nähdä, tarkista että sekin on hyvin kiinni.
