Astra G osanumeroita
Juhash
Viesti Kirjoittaja Juhash »
Nää vois vaikka lisätä moderaattorin toimesta vinkkeihin ja vihjeisiin, mutta tässä ois erittäin kattava lista tuiki tarpeellisia numeroita.
Sisältää myös hieman harvinaisemmat Vauxhall- ja Irmscher-numerot.
Numeroiden alkuperä viestin lopussa, joten en vastaa millään muotoa tiedon oikeellisuudesta.
Cooling systems
Water Temperature Sensors
X1.4XE/X1.6SZR/X1.6XEL/Z2.0LET 90541937
Coolant temperature sender/sensor 90530444 (X18XE1)
Z14XE/Z16SE/Z16XEP to 20Y66443 9193163
Z16XE to '02 9193163
Z16XE from '03 93174208
Z16XEP 93174208
X1.8XE1/Z1.8XE from 20Y66444 12992783
Z22SE 15326388
X17DTL - engine timing 9117449
Z17DTL 97227219
Y17DT 15326386
2.0Di/2.0DTi (blue) 90541937
Y20DTH (black) 90542063
Radiator Bottom Hoses
1.4 16v/1.6 16v man. trans. 9202896
1.6 8v 90573840
1.8 16v 90531666
2.0 16v with F18 man. trans. 90572917
2.0 16v with F23 man. & auto trans. 90573896
2.0 Turbo 90573896
1.7TD 8v 90530679
1.7DTi 16v 9229535
2.0Di 16v/2.0DTi 16v 90573220
Radiator Top Hoses
1.4 16v (to '00)/1.6 16v (exc. Twinport) without air con. 24413976
1.4 16v (to '00)/1.6 16v (exc. Twinport) with air con. 24413975
1.6 8v without air con. 24413974
1.6 8v with air con. 24413973
1.8 16v with air con. 24413977
1.7TD 8v 90573847
1.7DTi 16v/1.7CDTi 16v 9128908
2.0Di 16v/2.0DTi 16v 24421116
Radiators (with air con.)
1.4 16v/1.6 8v/1.6 16v exc. Z1.6XEP/1.8 16v 93177121
Z1.6XEP all man. models (exc. convertible/coupe) to 42105240/45110601/36999999/48999999 93177122
Z1.6XEP all man. models (exc. convertible/coupe) from 42105241/45110602 93179909
Z1.6XEP man. convertible/coupe to '03 93177122
Z1.6XEP man. convertible/coupe from '04 93179909
2.0 16v/2.0 Turbo/2.2 9201018
1.7TD 8v man. trans. 9193268
1.7DTi 16v/1.7CDTi 16v 9192586
2.0Di 16v F18+ man. trans. to X2117327/X5112266/X8046785 9201018
2.0Di 16v F18+/F23 man. trans. from X2117328/X5112267/X8046786 9192578
2.0Di 16v auto trans. 9201018
2.0DTi 16v 93174625
Radiators (without air con.)
1.4 16v/1.6 8v/1.6 16v/1.8 16v 9202493
2.0 16v F13/F17/F18/F23 man. trans. 9201018
2.0 16v auto trans. 93177121
1.7DTi 16v /1.7CDTi 16v 9192586
2.0Di 16v 9201018
2.0DTi 16v 93174625
Water Pumps
1.4 16v/1.6 16v exc. Twinport R1160030
1.6 8v to 02LC6175 R1160012
1.6 8v from 02MZ5254/20U75999 93182042
1.8 16v 90543935
2.0 16v/2.0 Turbo 24409355
1.7TD 8v to 14427284 24409355
Starting and Charging systems
Alternators
1.4/1.6 8v/1.6 16v/1.8/2.0/2.0 Turbo - 70 amp R1530035
1.4/1.6 8v/1.6 16v/1.8/2.0/2.0 Turbo - 100 amp R1610391
2.2 - 120 amp R1530048
1.4/1.6/1.8/2.0//2.0 Turbo - 120 amp R1530025
1.7DTi 16v - 70 amp R1530065
1.7DTi 16v/1.7CDTi 16v - 100 amp R1530037
1.7TD 8v - 70 amp R1530064
1.7TD 8v - 100 amp R1530039
2.0Di 16v/2.0DTi 16v - 70 amp R1530040
2.0Di 16v/2.0DTi 16v - 100 amp R1530041
2.0Di 16v/2.0DTi 16v - 120 amp, ident. TP R1530042
2.0Di 16v/2.0DTi 16v - 120 amp, ident. UU R1530043
Alternator Astra G 1.8 Sport A/C & ABS 100amp
Bosch 9195753
Delphi 9117851
Batteries, Aftermarket
1.4/1.6 - 44 amp/hr (GM44-T7) 93176572
1.8/2.0/Turbo/2.2 - 55 amp/hr (GM55-T7) 93176576
Diesel - 72 amp/hr (GM72-H3) 93176583
Batteries, OE
70 amp/hr 9201470
Ignition Coils/Coil Packs
1.4/1.6 16v exc. Twinport 19005212
X1.6SZR 10457075
Z1.6SE 10457870
Z1.6XEP 10458316
X1.8XE1/Z1.8XE 9119567
2.0 16v 90458250
2.0 Turbo 9198834
Z22SE (individual module) 10457983
2.2 from '03 - ignition control unit module assy. 12580537
Starter Motors
1.4/1.6 R1040008
1.8 to '02 R1540009
1.8 from '03 R1540011
2.0/2.0 Turbo R1540018
1.7TD 8v R1040028
1.7DTi 16v R1540010
2.0Di 16v R1540005
Engine
X16XE / Z16XE Engine R1000154
Cylinder Heads, Remanufactured
X1.4XE/Z1.4XE/X1.6XEL R1230063
X1.8XE1 R1230066
X1.7DTL R1230051
Air Temperature Sensors
X14XE/Z14XE/X16XEL/Z16XE - engine timing 12129596
Z22SE - engine timing 12160244
All models to 35034914 - electronic air conditioning 24413582
All models - outside air temp. 9152245
Airflow Meters
Z16XEP 25358054
1.8/2.0 16v 90530463
2.0 Turbo 9201425
1.7TD/1.7DTi 93171356
1.7CDTi 93177718
2.0Di/2.0DTi to '00 93171356
2.0Di from '01 93171355
2.0DTi from '01 to '02 93171355
2.0DTi from '03 93171527
Camshaft Sensors
X1.4XE/X1.6XEL 90412795
Z1.4XE/Z1.6XE 10456585
Z1.6SE 10456592
Z16XEP 24435096
X1.8XE1/Z1.8XE 90536064
2.0 exc. Turbo 90520850
Z20LET 93176039
Z17DTL 97306560
1.7TD 9118150
Crankshaft Sensors
X1.4XE/X1.6SZR/X1.6XEL 90520854
Z1.4XE/Z1.6XE/Z1.6XEP/Z1.6SE 10456604
X18XE1 90520856
Z1.8XE 9115115
X20XEV 90520855
Z20LET 93243251
Z22SE 12567712
Y17DTL 97226992
1.7DTi 97180388
X2.0DTL/2.0DTi to '03 90540188
Y20DTH from '04 93179850
Exhaust Gas Recirculation Valves
X1.4XE/X1.6XEL 17098361
Z1.4XE/Z1.6SE/Z1.6XE/X1.6SZR/X1.8XE1 17200272
Z16XEP 24445720
X20XEV 9202335
2.2 from 11003604 to 11292859 12569552
1.7TD 8v 9128118
1.7DTi 97218331
1.7CDTi 97355042
2.0DTi (Handtmann type) 93176989
Fuel Injection Control Units
2.0 Turbo 9164475
1.7DTi 97189136
Idle Speed Controls
X1.4XE/X1.6XEL 17113196
X1.6SZR 17112031
2.0 16v 90411546
1.7DTi/1.7CDTi 97219155
Knock Sensors
1.4/X1.6SZR/X1.6XEL/Z1.6SE/Z1.6XE 10456240
X18XE1 90536392
Z18XE 9158720
X20XEV 90530585
2.0 Turbo 90541521
Z22SE 12567711
Lambda Sensors
X1.4XE/X1.6XEL (cat.) 9118698
X1.4XE/X1.6XEL/Z1.6SE/Z1.6XE from '02 (front pipe) 93189975
Z1.4XE/Z1.6XE 93189974
X1.6SZR 25164596
Z1.6SE to '01 25323632
Z1.6XEP (position 1) 93181910
Z1.6XEP (position 2) 55560617
X1.8XE1 90536393
Z1.8XE 9202575
Z1.8XE (position 2) 9158718
X20XEV 90530586
2.0 Turbo 9193148
2.2 man. (rear pipe) 12567680
2.2 (exc. Convertible) from 12267298/15257080/26000001/28000001/1B021465/1H031257 (front pipe) 12569391
2.2 Convertible from 1B005183 (front pipe) 12569391
Oil Temperature Sensors
X17DTL/X20DTL/Y20DTL/Y20DTH 9198691
Oil Filler cap
Oil filler cap (1.6 16v) 90536291
Throttle Valve Bodies
Z1.4XE/Z1.6SE/Z1.6XE 9192122
X1.8XE1 90543949
Z1.8XE 9196357
2.2 from 11078670 93174608
1.7CDTi 97300231
X14XE/X16XEL 90541440
X16SZR 17113262
Z16XEP to 20CK5296 25329591
X20XEV 90544023
Inlet Manifolds
Inlet manifold # 90536060 (Z18XE)
Vacuum Sensors
1.7TD 8v/X2.0DTL 90541409
2.0DTi to '00 90541409
Y20DTH from '01 to '02 24420761
2.0DTi from '03 93171176
Vacuum Solenoid Valves
2.0Di/2.0DTi 9128022
Clutch Kits
X1.4XE, Z1.4XE (F13/F17 trans.), Z1.4XEP 93185891
X1.6SZR 93185875
Z1.6SE, X1.6XEL, Z1.6XE 93185877
X1.8XE1, Z1.8XE, Z1.8XEL 93185899
X2.0XEV (F18 trans.) 93185866
X2.0XEV (F23 trans.) 93185874
Z2.0LET 93185897
Z2.2SE (F23 trans.) 93185882
X1.7DTL 93185893
Y1.7DT, Z1.7DTL 93185900
X2.0DTL (F18+ trans.) 93185879
X2.0DTL, Y2.0DTL (F23 trans.) 93185880
Y2.0DTH to '02 (F23 trans.) 93185881
Y2.0DTH from '03 93185901
Complete VXR Turbo 55559850
11023582 Turbo water feed and return banjo washers 4 of at 12p each
11081452 Turbo oil feed banjo washers 2 of at 9p each
11017691 Oil return pipe to sump banjo bolt 2 of at 45p each
92065437 Stud M8 obviously 10 of if you intend on replacing them 44p each
90424073 nuts M8 10 of at 97p each
90424394 washer plate 1 of at £14.50 each
90424422 manifold to head gasket 1 of at £8.35 each
90424370 Turbo to precat gasket 1 of at £12.05 each
13101735 Precat to main cat gasket 1 of at £7.40 each
90424066 Oil return pipe to turbo gasket 1 of at 85p each
11064661 water feed and return banjo bolts 2 of at £3.18
11074992 oil return pipe to sump banjo bolt 1 of at £1.38
90513210 Mounting paste 1 of at £14.65 each
Head breathers / gaskets
90423733 for CYLINDER HEAD COVER TO TURBOCHARGER (rear)
90423667 for VENTILATION PIPE TO CYLINDER HEAD (front)
90501290 tube from crankcase to hose bend
90448217 gasket for oil filler cap
90412508 for new cap if yours is a be grubby
55558349 gasket cover to cylinder head
11098761 bolts to hold cover on 10 required for total change.
90528438 o ring to suite bolt
90423606 vent pipe to one way valve
90423045 non-return valve (crankcase vent)
90424285 one way to throttle body
Hoses/Hose clips
HOSE, VENTILATION, CYLINDER HEAD COVER TO AIR CLEANER ELBOW HOSE = 90412281
HOSE, VENTILATION, INDUCTION MANIFOLD AND CYLINDER HEAD COVER = 90528437 - ie the thinner of the two pipes which connects the head to the ind. manifold -
Hoseclip for above hose. 90469888
22mm I/D - Head side = 90467194
26mm I/D - Air intake side = 90572593
Top boost hose 90423532 (Z20LET)
Bonnet release cable 90521478
Exhausts
Exhaust Front Pipes
Z1.4XE/Z1.6XE/Z1.6SE 24423924
Z1.8XE 55561158
1.7DTi 16v 24423926
Exhaust Silencer and Centre Pipes
1.4i 16v 24423018
X1.6SZR 24423018
Z1.6SE to 32245936/35200188 24423017
Z1.6SE from 32245937/35200189 13129810
1.6i 16v to 32245936/35200188/36118145 24423017
Z1.6XE/Z1.6XEP (exc. coupe) from 32245937/35200189/36118146 13129810
1.8i 16v hatch/saloon/estate to 32279464/35200329 24423019
1.8i 16v coupe/convertible to 3B009312/3B017646 24423019
X1.8XE1/Z1.8XE hatch/saloon/estate from 32279465/35200329, coupe from 3B009313, convertible from 3B017647 13143424
2.0 16v hatch/saloon/estate 24423019
2.0 16v convertible to 3B017646 24423019
2.0 16v convertible from 3B017647 13143424
1.7DTi 16v hatch/saloon 13173597
1.7DTi 16v estate to '02 24423015
1.7DTi 16v estate from '03 13173597
1.7CDTi 16v hatch/saloon/estate to 42105078 13129236
1.7CDTi 16v hatch/saloon/estate from 42105079 13173597
1.7TD 8v 24423015
2.0Di 16v 24423016
2.0DTi 16v to '02 24423016
2.0DTi 16v from '03 to 32306709/45000269 24455254
2.0DTi 16v from 32306710/45000270 13138164
Exhaust Silencer and Tail Pipes
X1.4XE hatch from Y2230813/Y5326828 13158592
X1.4XE saloon 13158593
X1.4XE estate 13158594
1.6i 8v hatch from Y2230813/Y5326828/Y8155194/16000365 to 35200189 13158592
1.6i 8v saloon to 35200189 13158593
1.6i 8v estate to 35200189 13158594
Z1.6SE/Z1.6XE/Z1.6XEP hatch (exc. Sport version 2) from 5G000615 13158588
Z1.6SE saloon from 35200190 to 5G001742 13158589
Z1.6XE/Z1.6XEP saloon from 35200190/36118146 to 5G001742 13158589
Z1.6XE/Z1.6XEP estate exc. Sport from 5G001414 13158590
Z1.6XE/Z1.6XEP/Z1.6SE estate Sport to 32243489 13178913
X1.6XEL hatch to Y2230812/Y5326827/16000383/Y8155193 13183193
X1.6XEL/Z1.6XE saloon 13183195
X1.6XEL estate 13183196
Z1.6XEP hatch to 32245936/35200189 13183193
Z1.8XE1/Z1.8XE hatch to 32279464/35200293 13183205
Z1.8XE estate to 32279464 13183203
2.0 16v hatch 13183202
2.0 16v estate 13183203
1.7CDTi 16v hatch exc. Sport version 2 13128093
1.7CDTi 16v saloon 13128877
1.7CDTi 16v estate 13128705
1.7TD 8v/1.7DTi 16v hatch 13190137
1.7TD 8v/1.7DTi 16v saloon 24422989
1.7TD 8v/1.7DTi 16v estate 13190140
2.0Di 16v/2.0DTi 16v hatch to 15000435/18029701 13190137
2.0Di 16v hatch from 15000436/18029702 24432900
2.0DTi 16v hatch 15004536/18029702 to '02 24432900
2.0DTi 16v hatch from 32306710/45000270 13158600
2.0Di 16v/2.0DTi 16v saloon to 15000679 24422989
2.0Di 16v/2.0DTi 16v (exc. Sport) estate to 18029701 13190140
Exhaust Manifolds
Exhaust manifold # 9158633 (Z18XE)
Coupe Turbo Manifold & turbo 90423508 (Z20LET)
Fuel Pumps
1.4 16v/1.6 16v/2.0 16v to Y2042870/Y5052846/Y8026164 93181359
1.4 16v/1.6 16v/2.0 16v from Y2042871/Y5052847/Y8026165 9120218
X1.6SZR 93187033
Z1.6SE 9120218
1.8 16v to Y2042870/Y5052846/Y8038290 93181359
1.8 16v from Y2042871/Y5052847/Y8038291 9120218
2.0 Turbo/2.2 9196213
Suspension & Steering
Front Stabiliser Link Bars
To 42099951/45102774/4G025553 90498745
Lower Suspension Arms, Front
All models LH 90498735
All models RH 90498736
Shock Absorbers, Front (single)
Hatch/saloon/estate/convertible 1.4/1.6/1.8 exc. Sport, SXi, SRi LH 93170464
Hatch/saloon/estate/convertible 1.4/1.6/1.8 exc. Sport, SXi, SRi RH 93170465
Hatch/saloon/estate 1.4/1.6/1.8 Sport/SXi/SRi, Coupe 1.6/1.8 LH 93170491
Hatch/saloon/estate 1.4/1.6/1.8 Sport/SXi/SRi, Coupe 1.6/1.8 RH 93170492
Hatch/saloon/estate 2.0/2.2 exc. Sport, SXi, SRi LH 93170468
Hatch/saloon/estate 2.0/2.2 exc. Sport, SXi, SRi RH 93170470
Hatch/saloon/estate 2.0/2.2 Sport/SXi/SRi LH 93170514
Hatch/saloon/estate 2.0/2.2 Sport/SXi/SRi RH 93170515
Coupe/Convertible 2.2 LH 93170514
Coupe/Convertible 2.2 RH 93170515
Coupe 2.0 turbo LH 93172563
Coupe 2.0 turbo RH 93172564
Convertible 2.0 turbo LH 93170514
Convertible 2.0 turbo RH 93170515
Hatch/saloon/estate 1.7 diesel LH 93170468
Hatch/saloon/estate 1.7 diesel RH 93170470
Hatch/saloon/estate 2.0 diesel exc. Sport LH 93170491
Hatch/saloon/estate 2.0 diesel exc. Sport RH 93170492
Hatch/saloon/estate 2.0 diesel Sport LH 93170514
Hatch/saloon/estate 2.0 diesel Sport RH 93170515
Shock Absorbers, Rear (single) - with mounting parts
Hatch/saloon exc. 2.0 turbo 72119052
Hatch 2.0 turbo 72119101
Estate without levelling device 72119054
Estate with levelling device 72119091
Coupe 1.6/2.0 turbo 72119101
Coupe 1.8/2.2 to 1B014392 72119100
Coupe 1.8/2.2 from 1B014393 72119101
Convertible 1.6/1.8 72119052
Convertible 2.0 turbo 72119100
Convertible 2.2 to 1B014392 72119100
Convertible 2.2 from 1B014393 72119101
Steering Ball Joints
All models LH/RH 90512982
Steering Rack Boots
Repair Kit (one side) (Delphi) to Y2256498/Y8137607 26059295
Repair Kit (one side) All models (TRW) 93189459
Track Rod Ends
All models 93186537
Wheel Bearings, Front
Models without ABS, 4-stud hub 9117619
Models without ABS, 5-stud hub 9117621
Models with ABS, 4-stud hub 9117620
Models with ABS, 5-stud hub 9117622
Wheel Bearings, Rear
1.4 16v/1.6 8v/1.6 16v/1.8 16v without ABS 9120129
1.4 16v/1.6 8v/1.6 16v with ABS 9120128
1.8 16v/2.0 16v with ABS 9119931
1.7TD 8v/1.7CDTi 16v/1.7DTi 16v/2.0Di 16v without ABS 9120129
1.7TD 8v/1.7CDTi 16v/1.7DTi 16v with ABS 9120128
2.0Di 16v/2.0DTi 16v with ABS 9119931
2.0DTi 16v without ABS 9120273
CV Joint Boots
1.4i 16v/1.6i 8v/1.6i 16v outer (repair kit c/w clips) 90444342
1.4i 16v/1.6i 8v/1.6i 16v inner (repair kit c/w clips) 90009025
1.8i 16v/2.0i 16v outer (boot only) 90512357
1.8i 16v/2.0i 16v inner (repair kit) 92100311
1.7TD 8v outer (repair kit c/w clips) 90444342
1.7TD 8v inner (repair kit c/w clips) 90009025
1.7DTi 16v/2.0Di 16v/2.0DTi 16v outer (boot only) 90512357
1.7DTi 16v/2.0Di 16v/2.0DTi 16v inner (repair kit) 92100311
Braking System
GSI System
308mm Discs 9194477 (GSI)
308mm Pads 9195064 (GSI)
308mm carriers are #9195063 (GSI)
Brake Lining Wear Sensors
1.4/Z1.6SE/X1.6XEL/Z1.6XEP 13122323
X1.8XE1/Z1.8XE/2.0 Turbo/2.2 to 42187758/4B007184/4B003879 13122323
X18XE1/Z18XE/Z22SE/Z20LET from 42187759/4B007185/4B003880 13153473
1.7DTi/1.7CDTi 13122323
2.0DTi to 42187758/4B007184/4B003879 13122323
Y20DTH from 42187759/4B007185/4B003880 13153473
Brake Calipers, Remanufactured, Front
All models without ABS - RH R1740071
All models without ABS - LH R1740070
All models with ABS - RH R1740079
Also use front brake flange plate assembly 9192456.
All models with ABS - LH R1740078
Brake Cylinders, Rear Wheel
All models with drum brakes 90498300
Bleed screw 24461620
Brake Disc & Pad Kits, Front (axle set)
All models - 256 mm dia. 93175456
All models - 280 mm dia. 93175459
Brake Disc & Pad Kits, Rear (axle set)
All models - 240mm dia. Bosch caliper 93182594
All models - 240mm dia. Lucas caliper 93182595
All models - 264mm dia. Bosch caliper 93182596
All models - 264mm dia. Lucas caliper 93190173
Brake Discs, Front (pair)
2.0 Turbo - 308mm dia. disc 9194477
Brake Discs/Drums, Rear
Drum - all models (single) 24444064
Brake Pads, Front (pair)
All models - 256 mm dia. disc 9195144
All models - 280 mm dia. disc 9195145
2.0 Turbo - 308mm dia. disc 93179708
Brake Shoes/Pads, Rear (axle set)
All models brake shoes 90512792
Disc pads - Bosch caliper 9195147
Disc pads - Lucas caliper 93188727
Handbrake Cables
Front cable - all models 9127540
Centre cable - all models with drum brakes 24436451
Centre cable - all models with disc brakes to 22006460/25003001/16999999/28006254/IB999999 24425108
Rear cable - all models with drum brakes
Air ducts fitted on (G) 147PS plus engine
9201448 RH
9201447 LH
Bodywork
GSI Bumper
fogs 9270157
fog harness 9270158
skidpan / tray 9270159
bumper 9270160
grill (middle section) 9270161
grill RH 9270162
grill LH 9270163
OPC rear spoiler is 24405397
GSi (OPC) rear Bumper - 9270166
Flap, Towing Lug, Front End Panel, Primed (For OPC/GSi) - 93173889
Gsi B pillar foil all 3 door
Drivers Side door - 13126009
Drivers side rear quater - 13126010
Passenger side door - 13126021
Passenger rear quater - 13126022
GSI arch covers
o/s = 9201446
n/s = 9201445
SRI-T Front Bumper
Does Not Include Foglights - 93174616
SRI-T Side Skirts
Left - 93174203
Right - 93174681
SRI-T Rear
Single Pipe Exit - 93174617
Twin Pipe Exit - 93175478
Estate B Pillar trim - rear
Drivers side - 13126008
Passenger Side - 13126007
Front Arch Liners
o/s 24424504
n/s 24424503
3 Door Astra G - Primed bump strips (not GSI)
Front RH - 13128485
Front LH - 13128468
Astra G rubstrips from vauxhall already painted silver (4 Door)
9120278
9120276
9120268
9120270
Radio
Standard looking aerial stem, but shorter 24464153
Standard aerial base- 24447133
Door
Primed door handle LHS (no lock) :- 9194842
Primed door handle RHS (no lock) :- 9194844
Mirror(s)
Interior black trim without hole for manual adjustment
RH - 9100286
LH - 9100286
Mirror houseing with motor
RH - 9142147
LH - 9142148
Heated glass
RH - 9130906
LH - 9130907
Boot
coupe
Striker, lock, trunk lid - 90275077
Screw, Hex Head, M8 X 15, (Trunk lid Striker) - 9287766
Fuel Filler cap
FLAP,WITH HINGE,FUEL FILLER,PRIMER HATCH - 90543920
FLAP,WITH HINGE,FUEL FILLER,PRIMER SALOON - 9193211
FLAP,WITH HINGE,FUEL FILLER,PRIMER ESTATE,VAN,ZAFIRA - 90544227
FLAP,WITH HINGE,FUEL FILLER,PRIMER COUPE - 9195612
Badges
VXR Badge 93182628
OPC Side moulding badges 9194910
Rear 'Turbo' 9201492
SRI (side) 9196230
GSi (rear) 9196227
Rear Opel emblem 9200445
Holden conversion
Rear (emb) hatch 9117600
Rear (emb) coupe 90543888
Rear (word) 90541171
Centre Caps (Alloys)
Opel badge centre caps for alloy wheels 15/16" 9223038
4 Stud Wheel:- COVER,WHEEL HUB,OPEL 90496305
5 Stud Wheel:- COVER,WHEEL HUB,OPEL 90468692
Astra Sri/Coupe turbo Alloy wheel (5 spoke 17") centre cap - 9179671
Headlamps (inc. indicator)
RH non-tinted, exc. xenon 93175371
LH non-tinted, exc. xenon 93175370
Astra G Headlamp Bracket repair kit. - 9192631
Coupe dark tinted head lights (with adjusters) 9199897
Dipped beam bulb holder 9118046
Tail light plastic screw lug 24424603
Standard fog Light Unit
Offside 9117323
Nearside 9117322
Replacement bulb 90013537
GSIfogs 9270157
Indicators, Front
Side repeater, yellow, LH/RH to '98 9117660
Side repeater, white, LH/RH from '99 9120467
Rear Lamps
Hatch non-tinted - RH 9117403
Hatch non-tinted - LH 9117402
Saloon/Coupe non-tinted - RH 9117440
Saloon/Coupe non-tinted - LH 9117439
Estate non-tinted - RH 9117211
Estate non-tinted - LH 9117210
Side sills/skirt retaining clips - 9174457 Check for correct type!
Red clips that hold the rear quarter panels on coupes part # 90457899
Interior
Interior Door handle housing with hole for electric windows/mirrors
Right hand side is # 9100220
Left hand side is # 9100217
Switches for the windows
Three door # 9100301
Five door # 9100300
Passenger side # 9100299
Electric mirror switch is # 9226863
A relay is also required # 24432680
Floor Mats
Linea Rossa mats with embossed LR logo
Front Driver: 93175605
Front Passenger: 93175658
Electric Sunroof
Electric sunroof motor
Rockwell golde 90503754
Meritor 24436601
plastic surround and switch for sunroof
Cover (light grey) 90440303
Black insert (between Ashtray and gear stick surround)
TC Hole only 90437593
No holes Black 90437591
TC Switch 9104185
2 hole gunmetal panel is part number - 13117895
Switch Panel (Black - Without TC) - 90437559
3 hole TC panel in gun metal - 13129779
Three hole panel black (RHD) - 90437561
Moulding *BLACK* #90437559
Heated Cushion (Sports Seat) - 90560059
Heated Back Cushion (Sports Seat) - 90560060
Heated seat switch #90437528
Din storage compartment Black (not CD holder) 90437473
90437473 and 90437474 for the little rubber non-slip mat
1/2 Silver 1/2 Black centre console (not satnav) 13117927
Centre Console with A/C Gun Metal Grey 13117904
Centre Console with A/C Metal Anthercite 13117902
Matt Chrome Sat Nav Centre console. Part no: 13117931
Sat Nav Centre console Black (with A/C) 24436698
Sat Nav Centre console Black (without A/C) 9229371
Ashtray - black bits that can be lifted out to empty
One for 3 Door hatch (exc Star silver), 5 Door hatch, saloon, estate, van and Convertable - 90437575 (listed as Black)
The other for 3 Door hatch (Star silver), Coupe. - 9104666 (listed as Gun Metal Grey)
Sunglasses holder (Corsa C) Part Number 24413714 "Shelf Grey"
Glove box (BLACK) 90437507
Plastic clips to hold dash up 90218614
Gear Stick/knob
Gear stick assy. (Aluminium) 55350986
Vauxhall Alu Gearknob for the Astra G 93178339
Security
Power Sounder 9194454
Service
Glow Plugs (single)
1.7TD 8v 90510924
1.7DTi/1.7CDTi 16v 93187927
2.0Di 16v/2.0DTi 16v from 32123350 9118201
2.0DTi 16v to '02 9118201
2.0DTi 16v from '03 93178225
Oil Filters
X1.6SZR, Z1.6SE to O2PT5170 93156954
Z1.6SE from 02PT5171 93178952
Z1.6XE to 20BW7609 93156954
Z1.6XE from 20BW7610 93178952
Z1.6XEP to 20BW3256 93156954
Z1.6XEP from 20BW3257 93178952
1.8 16v to 20V00604 9192426
1.8 16v from 20V00605 to 20BW7583 93156954
1.8 16v from 20BW7584 93178952
2.0 93156954
2.0 Turbo 93178952
1.7TD 8v 90510935
1.7DTi 16v/1.7CDTi 16v 97223218
2.0Di 16v/2.0DTi 16v 9117321
Pollen Filters
All models - Standard pollen filter 13175553
All models - Combined dual action pollen & air filter 91132359
Spark Plugs (single)
1.4/Z1.6XE/1.8 to '03 (GM09) 9195109
Z1.6SE (GM32) 9195868
1.6 Twinport to '03 (GM32) 9195868
X1.6SZR/X1.6XEL/2.0/2.0 Turbo (GM09) 9195109
2.2 (GM33) 9199038
Fuel Filters
All petrol models 25313359
All diesel models exc. 1.7CDTi 16v 93185604
Wiper Blades
Front passenger side - all models 93177182
Front driver side - all models 91158551
Rear - hatch from '01 93187205
Rear - estate 93186488
A pair of Flat blade wipers for an Astra G Drivers side 500mm/20" Passenger side 450mm/18" 93189622
Air Filters
All petrol models exc. 2.2 91155714
1.7TD 8v 91155714
1.7DTi 16v/2.0Di 16v/2.0DTi 16v to '01 91155714
Fuel Filters
Fuel Filters - All petrol Models - 25320277
Cam Belt Kits
1.4 16v/1.6 16v exc. Z1.6XEP/1.8 16v to 02HL5117/20041690 93183572
1.4 16v/1.6 16v exc. Z1.6XEP/1.8 16v from 02HL5118/20041691 93185845
1.6 8v 93188126
Z1.6XEP 93185849
2.0 16v 93174263
1.7DTi 93188138
Cam Belts
1.4 16v/1.6 16v/1.8 16v 24451895
1.6 8v 90531677
2.0 16v/2.0 Turbo 55351782
1.7TD 8v 90530598
1.7DTi 16v 97212727
Fan Belts
1.4 16v/1.6 8v/1.6 16v exc. Twinport)/1.8 16v without air con. 93182264
1.4 16v/1.6 8v/1.6 16v exc. Twinport)/1.8 16v with air con. 93181317
2.0 16v without air con. 93182264
2.0 16v with air con. (100 amp alternator) 93182272
2.2 hatch/saloon/estate to 22176702/25159346/28093153 93182249
2.2 coupe to 2B006979 93182249
2.2 convertible to 2B008161 93182249
1.7TD 8v without air con. 90412115
1.7TD 8v with air con. 90571757
1.7DTi 16v without air con. 97186395
1.7DTi 16v with air con. 97229071
2.0Di 16v/2.0DTi 16v without air con. 24413293
2.0Di 16v/2.0DTi 16v with air con. 24413294
Accessories
Vauxhall Mudflaps
Front : 91146476
Rear : 91146477
General
Torx T20 and the part no. be 90561305
Imrscher
Tinted rear lights (hatch) i201207
irmscher center caps for an astra coupe i6110412
Mk 4 irmscher lowering springs Part No: i2003009
MK4 full supension kit? Part No: i2003002
Jack point covers Irmscher side skirts
All of them
RH Front - i2001354
RH Rear - i2001353
LH Front - i2001304
LH Rear - i2001303
Bonnet extension - i2001020
irsmcher rear spoiler for an astra g saloon - i2001411
tailgate trim chrome i2001474
Gun Metal Grey Gear Knob - i9517602
Grey Leather Gear and Handbrake gaiter - i2017030
Anodised Aluminium Door Pins i9517621
Smoked Oval side repeaters i1212041
Matt Silver (ally look) heater rings i2017159
Irmscher Line radiator grille i2001050
Irmscher Front air dam round fogs-----Mk4-----Zi2001003
Irmscher Suspension kit for 1.8 16v-----Mk4-----Zi2003006
Irmscher Roof spoiler for hatch-----Mk4----Zi2001407
Chrome heater rings----Mk4----Vi2017068
[http://www.astraownersclub.com/vb/archi ... 98769.html]
