Hello,
I need some help in English. I have an Astra F (hatchback, 1991) with engine block heater (Defa) and I want to install a so called "internal socket" (sisäpistoke).
I don't know to pass the electric cable from the engine compartment to the cabin: should I drill a hole, or a usable passage is already there? I need advices in this regard and also pictures of existing installations. So, if you happen to have an Astra F with "sisäpistoke", please post pictures showing the place where the cable enters the cabin (from both sides).
Thanks,
--Dan in Oulu
Astra F - Internal socket
DJ_Tatti
Re: Astra F - Internal socket
Usually the cable enters from the passengers side. There should be all ready hole for that cable.
There maybe some kind of rubberstopper where you have to make a hole for the cable.
Hope you understand what i'm talkin about
