Nonniih, luikastelumerkkivalo alkanut palaa ja luistelunesto kadonnut, sulakkeiden pitäis olla ehjät ja ABS kylläkin toimii; aiemmin vaihdettu etunapa jonka anturia mietin vialliseksi mutta absikaan ei vissiin toimisi (osan myyjän toteamus) jos siinä olisi vikaa, valo on ilmeisesti alkanut palaa myöhemmin navanvaihdon jälkeen, en ainakaan huomannut sitä uuden osan laiton jälkeen.
Eli onkos tuohon probleemaan kellään tiedossa vinkkejä?
Vectra c -07 z18xer luistonesto poissa
Re: Vectra c -07 z18xer luistonesto poissa
Eikös tuossa ole ennemminkin ESP ??
Vikakoodit kannattaa käydä luetuttamassa.
Muutama vaihtoehto :
Field Remedy: 2437
Subject: ESP Lamp - Illuminated
Models: Engines: Option:
Vectra-C 2006...2008,Signum 2006...2008 All,All ESP,without HSA (Hill Start Assistant) and without CDC (Continuos Damping System)
Complaint: ESP Lamp lit, DTC C0131 (08) set.
Cause: Sofware weakness.
Production: Improved Software has been implemented into production as of November 2007.
FunctionalGroup: H - Brakes
Complaint Group: 04 - Electrical failures,06 - Failure Code Setting by Control Unit
Trouble Code: C0131 (08)
Field Remedy: 1460
Subject: Colum Integration Module (CIM) - Misfunction of the Steering Angle Sensor (SAS)
Vectra-C 2002... All ESP
Complaint: Telltale lamp of the Electronic Stability Programm illuminates during driving, on the display of the tachometer appears the telltale sign of the Electrical Hydraulic Power Steering and the Turn signal light does not switch-off automatically.
Cause: Breakdown of the Steering Angle Sensor due to a wrong part assembly
Production:
Remedy:
In the case of a customer complaint the Column Integration Module has to
be checked. If the trouble codes B1012 and B1020 are stored as present or
as history then the Column Integration Modul has to be changed against a
new one with the latest status of manufacturing and software.
The part-/catalog number has not changed. Modules of the latest status are
marked with a blue dot.
The latest software status is OP94/12, this can be read out with TECH2.
The new parts are detectable in the second row of the coding under the
DELPHI logo – e.g. 020506 0005 with the meaning part number 5 on
production date 06. 05. 2002.
All parts with 020501 0001 and higher are all right.
FunctionalGroup: N - Electrical Equipment
Complaint Group: 04 - Electrical failures,06 - Failure Code Setting by Control Unit,13 - No/Poor Function
Trouble Code: B1012,B1020
Field Remedy: 2437
Field Remedy: 1460
Production:
Remedy:
Itellä -05 Vectra ja just tuota C0131-08 koodia pukkaa ihan satunnaisesti, täytyy kysellä päivitystä..
Vectra C Estate -07
Niin hullulta kun se kuullostaakin niin joskus aikoinaan zafiraan kun vaihdoin ilmamassamittaria ja vikaa etsiessä koitin ajaa IMM liitin irti niin se sytytti luistoneston valon ja poisti koko luistoneston käytöstä
Ei ehkä ensimmäisenä tulisi mieleen, mutta helppohan tuo on tarkistaa.
- Opel Vectra A -90, 1.8 C18NZ
"Ei päivää ettei tonnin vahinkoa!"
