OP-com Service Interval Reset
ciancarlo
Viesti Kirjoittaja ciancarlo »
Cars
Corsa-C
 Choose Body
 Choose Instrument
 Choose Programming
 Choose Service Interval Settings
Now enter the desired service interval reset.
Corsa-D
Possible displays:
 InSP - service
 InSp2 - bulp failure
 InSP3 - remote control battery
 InSP4 - water in diesel filter
 Choose Body
 Choose Instrument
 Choose Service Interval Reset
 Press the brake pedal
 Choose Yes
The Service Interval Is Now Reset .
Meriva
 Choose Body
 Choose Instrument
Astra-G
 Choose Body
 Choose Instrument
Astra-H
 Choose Body
 Choose Instrument
 Choose Yes
The service interval is now reset.
Zafira-A
 Choose Body
 Choose Instrument
Zafira-B
 Choose Body
 Choose Instrument
 Choose Yes
Tigra-B
 Choose Body
 Choose Instrument
Vectra-C
 Choose Body
 Choose Instrument
 Choose Yes
Signum
 Choose Body
 Choose Instrument
 Choose Yes
Insignia
 Press the brake pedal (keep pressed)
 Press the SET / CLR button in the Driver Information Centre
Antara
1. Turn the ignition key to ON/RUN with the engine off
2. Fully press and release the accelerator pedal three times within five seconds
 If the change engine oil light is not on, the system is reset.
 If the light comes on again and stays on for 30 seconds at the next ignition
cycle, it did not reset. You will need to reset the system again.
Vans
Combo-C
 Choose Body
 Choose Instrument
Now enter the desired Service Interval Reset value.
Vivaro
The Service Reset procedure should not exceed 1 and a half minutes to complete.
 Turn on the ignition.
 Press and hold the the accelerator fully
 Press the brake pedal down three times
 Release both pedals and wait 10 seconds
If it doesnt reset:
 Test drive the car for at least 5 miles
 Turn the ignition off for at least 60 seconds
 Repeat the above procedure
Movano 2007 - …
 press the brake pedal down three timesl
If it doesnt reset:
 Test drive The car for at least 5 miles
