x25xe kiristysmomentit
Tarvis kiristysmomentteja tietää x25xe koneeseen. Nokkapyörien momentti ja kampiakselinpyörän momentti. Ja mielellään jos joku tietäis suht nopeesti.
Opel Vectra 2,5 v6 -00
Peugeot 106 Gti -98
Lähes kaiken mitä insinööri on ryssinyt, voi ihminen korjata.
Peugeot 106 Gti -98
Re: x25xe kiristysmomentit
Tuossa taulukko :
https://docs.google.com/open?id=0B66Ek2 ... FM3X3FlUXc
Kiitos nopeasta vastauksesta!
Nyt on vaihdettu 4x nokka-akselin stefaa ja kampiakselin stefa. Jakopään remontti luonnollisesti myös!
Peugeot 106 Gti -98
Peugeot 106 Gti -98
Ole hyvä. Hyvä, että vaihdettua sait.
Recommended Torque Values – V6X 25 XE, Y 26 SE, X 30 XE, Y 32 SE
Nm
Adapter, fuel distributor pipe to intake bridge 8
Adapter, fuel distributor pipe to fuel distributor pipe 15
Starter to cylinder block 40
Intake bridge to intake flange 20
Intake flange to cylinder head 20
Drive disc / flywheel to crankshaft 65 + 30° + 15° 1) 2)
Exhaust manifold to cylinder head 20 3)
Oil filter housing cover to oil filter housing 25
Heat exchanger cover to heat exchanger 30
Heat exchanger cover to cylinder block 20
DIS ignition module to member 8
Torsional vibration damper to toothed belt drive gear 20
Throttle body to intake plenum 8
Pressure line to power steering pump 28
Accelerator pedal module to bulkhead 20
Link rod to stabiliser 65 3)
Alternator to cylinder block and oil pump 35
Transmission to cylinder block (M8) 20
Transmission to cylinder block (M12) 60
Transmission holder to underbody 45 4)
Threaded sleeves to crankshaft bearing bridge 8
Base plate, toothed belt tension roller and toothed belt guide roller to cylinder head 40
Auxiliary aggregate(s) support to cylinder block 35
Idler bracket to body 55 + 75° + 15° 1)
Rear toothed belt cover to cylinder head and oil pump (M6) 8
Rear toothed belt cover to cylinder head and oil pump (M8) 10
Crankshaft pulse pick-up in cylinder block 8
Crankshaft pulse pick-up disc to crankshaft 15 1)
Refrigerant lines to compressor 40
Ribbed V-belt pulley to coolant pump 8 + 30° + 30° 1)
Ribbed V-belt pulley to power steering pump 20 + 30° + 15° 1)
Ribbed v-belt tension roller to cylinder head 35
Knock sensor to cylinder block 20
Fuel lines to adapter, fuel distributor pipe 15
Fuel distributor pipe to intake bridge 8
Coolant bridge to cylinder head 30 5)
Coolant intake pipe to exhaust manifold 8
Coolant intake pipe to cylinder block 20
Coolant pump to cylinder block 25
Coolant pipe and engine transport shackle to cylinder head 25
Ball joint to steering knuckle 100 3)
Crankshaft bearing bridge to cylinder block 20
Crankshaft bearing cap and crankshaft bearing bridge to cylinder block cylinder block 50 + 60° + 15° 1)
Oxygen sensor in front exhaust pipe 30 6)
Steering arm to steering shaft 160 3)
Solenoid valve for intake plenum switchover valve to switchover valve 8
Secondary air metal pipe to exhaust manifold 20
Engine damping block to engine bracket 40
Engine vent housing to cylinder block 8
Engine damping block to front axle body 55
Engine bracket to cylinder block 40
Engine bracket, engine damping block to cylinder block 60
Camshaft bearing caps to cylinder head 8
Camshaft sprocket to camshaft 50 + 60° + 15° 1)
Camshaft sensor to camshaft bearing cap 8
Oil drain bolt to oil pan (inner Torx bolt) 10
Oil drain bolt to oil pan (hex bolt) 55
Oil pressure switch to oil pump 40
Oil filter to cylinder block 15
Oil filter casing to cylinder block 45
Oil lines (banjo bolt) to heat exchanger 30 + 30° + 15° 1)
Oil lines to cylinder block 30
Oil pump to cylinder block (up to MY '99) – M6 bolt 8 + 10 7) 8)
Oil pump to cylinder block (as of MY '99) – M8 bolt 12 + 20 8) 9)
Oil intake pipe to oil pump and to crankshaft bearing bridge 8
Oil baffle plate to crankshaft bearing bridge 8
Oil feed and return lines to cylinder block 30
Upper part of oil pan to transmission housing – M8 bolt 20
Upper part of oil pan to transmission housing – M10 bolt 40
Upper part of oil pan housing to cylinder block and oil pump 15
Lower part of oil pan housing to upper part of oil pan housing 8 + 30° 1)
Con-rod bearing cap to con-rod 35 + 45° + 15° 1)
Wheel to wheel hub 110
Intake plenum to intake bridge 8
Shift outrigger to transmission 20
Hose clamps for air intake hose 3.5
Clamp, fuel pressure regulator to fuel distributor pipe 5
Vibration damper to front axle body bracket and to engine bracket 40
Coolant temperature sensor in coolant bridge 18
Tie rod to steering knuckle 60 3)
Support to exhaust gas recirculation valve adapter 20
Tank vent valve to engine vent housing 8
Temperature sensor to coolant bridge 18
Thermostat housing to cylinder block 20
Union nut to screw-on connection, exhaust gas recirculation valve adapter 25 10)
Intake plenum switchover valve to intake plenum 8
Brake servo vacuum line to intake plenum 20
AC compressor to auxiliary aggregates support 35
Oil pressure regulating valve screw plug to oil pump 60
Closure bolt, safety valve to oil pump 30
Front axle body to body (front) 65 + 30° + 15° 1)
Front axle body to side member (centre) 150 + 30° + 15° 1)
Front axle body to side member (rear) 130 + 30° + 15° 1)
Front toothed belt cover to rear toothed belt cover 8
Front exhaust pipe to exhaust manifold 30
Pre-volume chamber to fastening points 2.5
Exhaust gas recirculation corrugated pipe to exhaust gas recirculation valve adapter and exhaust manifold 25
Toothed belt tension roller to bracket 20
Toothed belt guide roller to cylinder block 40
Toothed belt guide roller to toothed belt tension roller bracket 40
Toothed belt guide roller to oil pump 40
Toothed belt drive gear to crankshaft 250 + 45° + 15° 1)
Spark plugs to cylinder head 25
Cylinder head to cylinder block 25 + 270° + 15° 1) 11) 12)
1 ) Use new bolts.
2 ) Insert bolts with bolt locking compound (red).
3 ) Use new nuts.
4 ) Clean thread and insert bolts with bolt locking compound (red).
5 ) Use new copper seal rings.
6 ) When re-using oxygen sensor, coat thread with special grease (black).
7 ) Tightening to 10 Nm is performed after 10 minutes for the old version (without additional bore) and only after assembly of the complete toothed belt drive for the newer version.
8 ) Clean thread of fastening bolts and insert with bolt locking compound (red).
9 ) Tightening to 20 Nm is only performed after installation of the lower alternator fastening bolt.
10 ) Before assembly, coat thread of screw-on port with assembly paste (white).
11 ) In three stages of 90° each.
12 ) Retightening not required.
Nm
1 ) Use new bolts.
3 ) Use new nuts.
Viimeksi muokannut Rookeri, 29 Elo 2016, 15:54. Yhteensä muokattu 1 kertaa.
Syy: Hymiöt poistettu.
