Laadukkaita Fidanza alumiinivauhtipyöriä on käytetty mm. ratakilpa-autoissa
vuodesta 1980 lähtien.
6061 T6 tai 2024 T3 alumiinia
1050 korkeahiilipitoisesta teräksestä valmistetut kitkapinnat
lämpökäsitellyt hammaskehät
lentokoneisiin laatuluokitelluilla tarvikkeilla
kevyempiä kuin vakio = parempi kiihtyvyys varsinkin pienillä vaihteilla, moottori pääsee nopeammin turboviiven ohitse
Audi
Ford
Honda
Opel
Saab
Subaru
Toyota
Volkswagen
Fidanza alumiinivauhtipyörät virityskäyttöön
Opel moottoreihin
Hinnasto 06/2003
huom! alv 0% eli lisää alv 22 % hintoihin Suomessa
C20XE 2,0-16v v 88-92 vakiokytkimelle
hinta: 439 eur, tarjous, hinta: 399 eur
C20XE 2,0-16v v 88-92 7,25"/184mm kisakytkimelle
hinta: 439 eur, tarjous hinta: 399 eur
C20XEV 2,0-16v Ecotec vakiokytkimelle
hinta: 479 eur, tarjous hinta: 439 eur
Aluminum flywheels have been used for many years for increasing performance. From the earliest days of racing and street build-ups, the world's best engine builders have been installing aluminum flywheels to give their engines the needed edge.
Not only will you see a dramatic increase in usable horsepower, but engine life can also be extended since there will be less stress on the crankshaft.
How Does A Fidanza Flywheel Give Me So Much Added Power?
To achieve the greatest increase in performance an aluminum flywheel must lower the moment of inertia characteristics of the engine. Put in simpler terms, we must reduce the amount of horsepower needed to turn the flywheel so that horsepower can be used to turn the wheels.
Making the flywheel lighter is not as simple as it sounds. Anyone can take the factory design and then just produce that from aluminum. At Fidanza Flywheels we take the extra effort to eliminate the weight in areas that make sense for performance.
We do not sacrifice durability. We will not sell a flywheel that will not hold up to the roughest of drivers and or engines. This is where Fidanza Flywheels have the edge. Our flywheels give the best increase in performance but they are also the most durable. What a concept!
Anyone can claim to make a product that far exceeds industry standards but we choose to put our money where our mouth is.
From the very best materials to ground breaking new designs, Fidanza Flywheels are the finest aluminum flywheels on the market.
Please allow us a moment to introduce you to the most exciting product line to hit the automotive aftermarket in many years.
Let's Talk Quality
Fidanza Flywheels are made using the highest quality and most modern materials available.
The flywheel itself is made from either 6061 T6 or 2024 T3 aluminum depending on the model. Both of these materials are tempered aluminum which are very, very strong yet very lightweight.
The friction surface is very special. We use a 1050 high carbon, alloy steel. This alloy is perfect for this use. It is incredibly durable allowing the use of just about any clutch disc material available from organic to Kevlar and even sintered iron.
We attach the friction surface using aerospace nuts and bolts or 304 stainless steel rivets depending on the application. These are some of the best fasteners money can buy. We chose them because of their incredible shear strength and resistance to corrosion.
All of our ring gears are heat treated for durability. They are heated, pressed on and then secured using grade 10 fasteners.
You will not find better materials but keep reading because our machining and design process will knock your socks off.
Most companies design their flywheels so that they can be machined quickly and with the least amount of effort.
At Fidanza Flywheels we design our flywheels to produce the best increase in performance and the most durability.
Sometimes that means sacrificing a little profit on our end but we think you and your customers will agree, it's well worth it.
How Does Fidanza Flywheels Do That?
Fidanza Flywheels are machined and designed to be the very best flywheel on the market.
All of our flywheels are CNC machined. This process gives them the most accurate dimensions and the best possible finish. We use the very latest techniques to ensure that our flywheels are innovative and functional.
Our friction surface is laser cut with the fastener holes and chamfers CNC machined. The pattern for the fasteners is a computer design that keeps the friction surface from warping. We don't just use more fasteners because we can, we use them because they are needed.
Our designs can only be described with one word - AMAZING !
myynti@prostreet.fi
http://www.prostreet.fi
alumiinivauhtipyörät, parempi kiihtyvyys
1 viesti
• Sivu 1/1
ProStreet
1 viesti
• Sivu 1/1
Palaa sivulle “Moottorit ja voimansiirto”
Hyppää
- Opel Club Finland
- ↳ Uutiset ja tiedotteet
- ↳ Jäsentiedotteet
- ↳ Jäsen materiaali
- ↳ Tapahtumat ja OCF-keskustelu
- ↳ OCF alueet
- ↳ Ladies Only
- ↳ Yhteistyökumppaneiden tiedotteet
- ↳ Rompetori OCF Summerpartyilla
- Opel - tekniikka
- ↳ Opel-keskustelu
- ↳ Bongaukset
- ↳ Opel-gallupit
- ↳ Moottorit ja voimansiirto
- ↳ Diesel
- ↳ Virittäminen
- ↳ Ahdetut moottorit
- ↳ Vapaasti hengittävät moottorit
- ↳ Tekniikan vaihdot
- ↳ Voimansiirto
- ↳ Moottorinohjaimet, lastut ja ohjelmointi
- ↳ Diesel moottorit
- ↳ Kori ja sisusta
- ↳ Autohifi
- ↳ Ilmastointi ja lämmitys
- ↳ Alusta
- ↳ Projektit ja esittelyt
- ↳ Pienoismallit ja keräilyesineet
- Yleistä
- ↳ Moottoriurheilu
- ↳ Vitsejä, juttuja ja netistä löydettyä
- ↳ English
- Rompetori
- ↳ Rompetori
- ↳ Kerro hyvästä ja huonosta kaupantekokumppanista
- ↳ Myydään autoja
- ↳ Myydään osia ym.
- ↳ Myydään autohifiä
- ↳ Myydään renkaita ja vanteita
- ↳ Ostetaan
- ↳ Lahjoitetaan ja myydään muut
- Extra
- ↳ Testit
- ↳ Nettisivupalaute
