Sattui tuolla surffaillessa eteen aika näppärä sivusto eli pien vinkki, jos asiasta kiinnostuneita...
OBDII/EOBD diagnostics trouble codes definition
If your car supports OBD II or EOBD, then you can already use almost 5000 generic OBDII codes. These codes are from PowerTrain series (P0XXX, P2XXX, P34XX), Body Series (B0XXX), Chassis series (C0XXX), Network series (U0XXX, U2XXX, U3XXX). Also there is a list of more than 13500 additional manufacturer specific codes.
http://obdii.pro/en/
Nettivinkki vikakoodien tulkintaan (useita automerkkejä)
wowfellows
Astra H 1.8 4D Hatchback '06 Z18XE (2023-)
Astra G 1.6 Twinport Njoy Caravan '04 Z16XEP (2019-2023)
Astra G 1.6 16v Elegance Caravan '01 Z16XE (2009-2019)
