Combo/corsa c mittariston vaihto
Nile_
Viesti Kirjoittaja Nile_ »
Comboon meinasin vaihtaa valkeepohjasen mittariston c corsasta(1.3 cdti.stä 1.7cdti.hin) ni ei lähe käyntiin tolla mittaristolla.. vilkuttaa auto/jakarin kuvaa..
Miten sen saa koodattua ko. Autoon..
Entä saako kilometrejä muutettua mistään todellisiksi.
Signum 2.0t -03
Omega B2 Caravan 3.0 V6 sport -00
Kadett d 5d farkku 1.8 ohc -84
MB Sprinter w906 315 CDi -09
Jamih
Re: Combo/corsa c mittariston vaihto
Viesti Kirjoittaja Jamih »
Nuo molemmat pitäisi onnistua opcomilla. Törmäsin brittifoorumilla seuraavaan kun etsin ratkaisua omaan mittaristopulmaan.
" Assuming you have your own cars pass code and the new clocks are fitted:- The first thing you need to do is connect to the instruments and go to EEPROM menu and pull the pin code(security code) from them for the new clocks. Once you have this you can then reset the clocks in the programming menu of the instruments by entering the security code and selecting reset IPC. switch ignition off for 30 seconds then back on.
Once they are reset you then program the new clocks by going to the programming menu and selecting the program IPC and then put your cars original security code in. You should get a message back saying successful. Once appears. Clear ALL codes and turn ignition off for 30 seconds. You should now be able to start the car.
If you dont have your own cars pass code fit the old clocks and pull the code using the method in first paragraph
NOTE - Access to the IPC is only available using firmware version 1.39 "
https://www.vauxhallownersnetwork.co.uk ... er.411499/
Eikö noita pohjia saa vaihdettua mittaristosta toiseen?
Nile_
Joo vaihdoin pohjat ristiin. Kiitti vinkistä :thumbsup:
Signum 2.0t -03
