En pidä näitä koodeja tai niiden sytyttämää moottorivikavaloa huolestuttavana, mutta osaisko joku selkokielellä sanua mikä vika autossa on, kun tällaisia herjaa:
Car Scanner ELM OBD2
DTC report
Selected brand: Opel
VIN: W0L0TGF3512133749
============1==============
C3022(39)
Raw code: 702239
ECU: 11
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test not completed since last DTC clear, Test failed since last DTC clear, Warning indicator requested
============2==============
C3895(01)
Raw code: 789501
ECU: 11
Status: Test failed
============3==============
U3111(7F)
Raw code: F1117F
ECU: 11
Status: Test failed, Confirmed, Test not completed since last DTC clear
============4==============
P0170
Raw code: 0170
ECU: 11
Status: Pending fault present during this driving cycle, Validated and stored in non volatile memory
OBDII: Fuel trim (FT), bank 1 - malfunction
============5==============
P0170
Raw code: 0170
ECU: 11
Status: Confirmed
Mihin nämä vikakoodit suomennettuna liittyy?
JarkkoK
Taivaspaikan pääsylippuni ovat Astra G Caravan 1.8 vm.2001 ja Astra G Hatchback 1.6 16V vm.2001
