Olisi tarvetta kadett 1.6i 91 kannenpulttien momenttiarvoille.
Kun on tuo kirja jonnekin hukkunut.
aj
momentti
KADETT GT/E
- OCF Member 2015
oliskos noista apua
Cylinder head bolts:
1.3, 1.4 litre and 1.6 (16SV and C16NZ) litre engines:
Stage 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 Nm
Stage 2 . . . . . . .. . . . . . . . . . . . . . . . . . . . . Angle tighten a further 60º
Stage 3 . . . . . . .. . . . . . . . . . . . . . . . . . . . . Angle tighten a further 60°
Stage 4 . . . . . . .. . . . . . . . . . . . . . . . . . . . . Angle tighten a further 30°
Warm the engine up to normal operating temperature then . . . . . . . Angle tighten a further 30°
1.6 (16SH), 1.8 and 2.0 litre engines:
Stage 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25Nm
Stage 2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Turn bolt through 60°
Stage 3 . . . . . . . . . . . . . .. . . . . . . . . . . . . . . . . . Turn bolt through 60°
Stage 4 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Turn bolt through 60º
Warm the engine up to normal operating temperature then . . . . . . . Angle tighten a further 30º
manta b -77
manta a -71 http://i58.photobucket.com/albums/g266/ ... G_1674.jpg
harley davidson xl 1200 http://i58.photobucket.com/albums/g266/ ... vat016.jpg
vw passat 1.8T BSR
vw passat 1.8T BSR
