Jumittaako foorumi
mimmix
Lurttinen
- Jäsennumero: 1227
mimmix
jamata
Tuli tämmönen teksti:
function checkFieldType(type){ if(type == "submit" || type == "reset" || type == "hidden"){ return false } else { return true } } function fIt(){ /* ****************************************************************************************** ** BLOCK FOCUS INSTRUCTIONS ** The following array named "noFocusPages" was constructed to block the focus script on certain pages. ** The array contains a default list of blocked pages using subsilver template which do not play nice with this script. ** You may add to or from the default list, just be sure the element indexes (numbers between the "[]") ** are in chronological order after making changes. If you don't want any pages blocked, just comment out ** the elements (by placing 2 slashes "//" in front of each element statement). ****************************************************************************************** */ var noFocusPages = new Array() noFocusPages[0] = "index.php" noFocusPages[1] = "viewforum.php" noFocusPages[2] = "viewtopic.php" noFocusPages[3] = "profile.php?mode=viewprofile" noFocusPages[4] = "search.php" noFocusPages[5] = "faq.php" noFocusPages[6] = "posting.php" noFocusPages[7] = "privmsg.php" //noFocusPages[6] = "search.php?search_id=newposts" //noFocusPages[7] = "search.php?search_id=unanswered" //noFocusPages[8] = "search.php?search_id=egosearch" //noFocusPages[6] = "SampleCommentedOutElement.php" this is how to comment out an element var 0
Voi olla et tuo mun mokkulayhteys pätki tai jotai mut yhtäkkiä tommonen pomppas ruudulle
Skoda Octavia -08
Lurttinen
- Jäsennumero: 1227
madi
- OCF Moderaattori
Nipe
- OCF Member 2015
Juheksi
- in memoriam
Lurttinen
- Jäsennumero: 1227
Oon tässä koko päivän surffannut palttiarallaa tunnin/korkeintaan kahden välein tänne ja kertaakaan jumittanut. Myös viestejä on tullut tasaiseen tahtiin.Nipe kirjoitti:Muutamaan tuntiin päässy kerhon sivuille ollenkaanmuut sivut toimi moitteetta
Se nyt ei vielä paljoa kerro vaikka osa netistä toimii moitteetta.
vrt, vaikka teliasoneran viimeisin taisto cogentin kanssa.
Varmaan jossain reitittimessä ollut vikaa ja ispiltä kesti pari tuntia vaihtaa, tjsp...
Mulla oli sunnuntaina puolen yön molemmin puolin sama juttu, joitakin muita sivuja oli myös minne en päässyt. Puhelimella kuitenkin pääsin samaan aikaan foorumille ja noille muillekin sivuille ihan normaalisti joten vika ei ollut ainakaan foorumissa.Nipe kirjoitti:Muutamaan tuntiin päässy kerhon sivuille ollenkaanmuut sivut toimi moitteetta
Nipe
- OCF Member 2015
Illan/yön aikana olin yhen kaverin kans messengerin välityksellä puheissa ja pyysin häntäkin koittamaan toimisko sillä OCF:n sivut niin ei toiminu ja molemmilla sekä mulla että kaverilla on soneran nettiliittymät, eli pistetään soneran piikkiinLurttinen kirjoitti:Se nyt ei vielä paljoa kerro vaikka osa netistä toimii moitteetta.Nipe kirjoitti:Muutamaan tuntiin päässy kerhon sivuille ollenkaanmuut sivut toimi moitteetta
Lurttinen
- Jäsennumero: 1227
Nipe
- OCF Member 2015
Hensku
