ElmScan 5 Scan Tool ja Vectra '00 X25XE
camus
Kaverilla oli tuommonen ElmScan 5 Scan Tool ja kokeilin sitä tuohon omaan Vectraan eikä onnistunut yhteys ainakaan ensi yrittämällä. Onko tuossa autossa edes OBD-II protokollaa eli voiko tuo laite toimia edes teoriassa?
Ex. Vectra V6
Omega V6
Omega V6
camus
edit: Samainen laite toimii -98 X20DTH Vectrassa, mutta ei minulla. Mikähän siinäkin on.
vauxhallownersnetwork.co.uk löytyi seuraavaa:
EOBD as it's known in Europe is equivalent to OBD2 in North America but wasn't mandatory in Europe until 2001 for petrol and 2004 for diesels.
GM Europe, ie Opel/Vauxhall, delayed compliance on petrol engined cars until the last minute. So, Vauxhall petrols are only EOBD/OBD2 compliant from Sept 2001 onwards, ie Z----- engines.
Earlier cars had an EOBD/OBD2 type of diagnostic socket but weren't compliant. The ECU of many of these earlier cars was internally compliant with EOBD/OBD2 but software only allows Tech2 interfaces.
Ex. Vectra V6
Omega V6
Omega V6
