Prostreetin pete!!
Venom
Minkä hintaisia on 1.3. ohc kadetin/asconan kireämmät nokat.. Tarkoitus olisi laittaa hyvä katunokka kyseiseen peliin? samalla olisi tarkoitus avartaa hieman kanavia ja höylätä siivu pois kannesta.. 40mm tuplat on ilmeisesti sopivan kokoiset kaasarit. Kaippa tuolla yhdistelmällä saa jo suht pirteän paketin kevyessä autossa..
ProStreet
Cat Cams hydr. katunokat Opel ohc 8v "small block":
partnr
duration@0.1mm
timing@0.1mm
max.lift (mm)
lift@TDC (mm)
clearance (mm)
duration@0.050"
timing@0.050"
max. lift (inch)
lift@TDC (inch)
clearance (inch)
peak angle
followers
springs
retainers
infolink
4600381
264° - 268°
19/65 - 67/21
9.50 - 9.50
0.70 - 0.80
hydro
212° - 212°
-7/39 - 39/-7
0.373 - 0.374
0.028 - 0.031
hydro
113° - 113°
STD
STD
STD
41,151
4600318
274° - 274°
25/69 - 69/25
9.70 - 9.70
1.00 - 1.00
hydro
216° - 216°
-4/40 - 40/-4
0.383 - 0.383
0.039 - 0.039
hydro
112° - 112°
STD
STD
STD
151
4600300
264° - 264°
21/63 - 63/21
10.25 - 10.25
0.90 - 0.90
hydro
212° - 212°
-5/37 - 37/-5
0.404 - 0.404
0.035 - 0.035
hydro
111° - 111°
STD
STD
STD
42,151
4600313
264° - 264°
24/60 - 60/24
10.25 - 10.25
1.10 - 1.10
hydro
212° - 212°
-2/34 - 34/-2
0.404 - 0.404
0.043 - 0.043
hydro
108° - 108°
STD
STD
STD
43,151
4600315
272° - 270°
24/68 - 67/23
10.55 - 10.50
1.20 - 1.20
hydro
222° - 222°
-1/43 - 43/-1
0.415 - 0.413
0.047 - 0.047
hydro
112° - 112°
STD
STD
STD
151
4600320
284° - 284°
35/69 - 69/35
10.60 - 10.60
2.00 - 2.00
hydro
228° - 228°
7/41 - 41/ 7
0.418 - 0.418
0.079 - 0.079
hydro
107° - 107°
STD
STD
STD
151
4601024
270° - 270°
21/69 - 69/21
11.20 - 11.20
0.80 - 0.90
hydro
218° - 216°
-5/43 - 42/-6
0.442 - 0.442
0.031 - 0.035
hydro
114° - 114°
STD
902-3009
99353
7,151
4601003
270° - 270°
26/64 - 64/26
11.20 - 11.20
1.30 - 1.20
hydro
218° - 216°
0/38 - 37/-1
0.442 - 0.442
0.051 - 0.047
hydro
109° - 109°
STD
902-3009
99353
7,151
Infolink
7
In some small block engines, the retainer will hit the valve seal at 11mm lift and more. distance between valve seal and retainer is to be adjusted!
41
Sport version for 1400-1600 OHC
42
Sport version for 1300N OHC
43
Sport version for 1300S OHC
151
rocker ratio at full lift varies and depends from valve length, base circle, cam lift etc.
For the catalogue data, we perform a simulation based on OEM geometry data corrected for catcams' actual base circle
Please keep in mind that these calculations are very sensitive on geometrical data, flexibility of rocker arms/shafts etc. No simulation of this kind will ever be 100% error free
Cat Cams hydr katunokat Opel ohc 8v 1,2-1,6 "small block" h 292e
keinut 80e
hydrot h 80e
Cat Cams jouset h 84e srj
Cat Cams aluretainerit h 111e srj
_________________
Pete
http://www.prostreet.fi
myynti@prostreet.fi
tel +358-19-469640
gsm +358-400-790019
gsm +358-41-5132882
fax +358-19-469600
<font size=-1>[ This Message was edited by: ProStreet on 2002-09-18 13:30 ]</font>
partnr
duration@0.1mm
timing@0.1mm
max.lift (mm)
lift@TDC (mm)
clearance (mm)
duration@0.050"
timing@0.050"
max. lift (inch)
lift@TDC (inch)
clearance (inch)
peak angle
followers
springs
retainers
infolink
4600381
264° - 268°
19/65 - 67/21
9.50 - 9.50
0.70 - 0.80
hydro
212° - 212°
-7/39 - 39/-7
0.373 - 0.374
0.028 - 0.031
hydro
113° - 113°
STD
STD
STD
41,151
4600318
274° - 274°
25/69 - 69/25
9.70 - 9.70
1.00 - 1.00
hydro
216° - 216°
-4/40 - 40/-4
0.383 - 0.383
0.039 - 0.039
hydro
112° - 112°
STD
STD
STD
151
4600300
264° - 264°
21/63 - 63/21
10.25 - 10.25
0.90 - 0.90
hydro
212° - 212°
-5/37 - 37/-5
0.404 - 0.404
0.035 - 0.035
hydro
111° - 111°
STD
STD
STD
42,151
4600313
264° - 264°
24/60 - 60/24
10.25 - 10.25
1.10 - 1.10
hydro
212° - 212°
-2/34 - 34/-2
0.404 - 0.404
0.043 - 0.043
hydro
108° - 108°
STD
STD
STD
43,151
4600315
272° - 270°
24/68 - 67/23
10.55 - 10.50
1.20 - 1.20
hydro
222° - 222°
-1/43 - 43/-1
0.415 - 0.413
0.047 - 0.047
hydro
112° - 112°
STD
STD
STD
151
4600320
284° - 284°
35/69 - 69/35
10.60 - 10.60
2.00 - 2.00
hydro
228° - 228°
7/41 - 41/ 7
0.418 - 0.418
0.079 - 0.079
hydro
107° - 107°
STD
STD
STD
151
4601024
270° - 270°
21/69 - 69/21
11.20 - 11.20
0.80 - 0.90
hydro
218° - 216°
-5/43 - 42/-6
0.442 - 0.442
0.031 - 0.035
hydro
114° - 114°
STD
902-3009
99353
7,151
4601003
270° - 270°
26/64 - 64/26
11.20 - 11.20
1.30 - 1.20
hydro
218° - 216°
0/38 - 37/-1
0.442 - 0.442
0.051 - 0.047
hydro
109° - 109°
STD
902-3009
99353
7,151
Infolink
7
41
42
43
151
keinut 80e
hydrot h 80e
_________________
Pete
myynti@prostreet.fi
tel +358-19-469640
gsm +358-400-790019
gsm +358-41-5132882
fax +358-19-469600
ProStreet
